8400 MFWD hub
8400farmer
11-27-2007 19:11:28
Got 85-140 oil leaking out of front hub, got new seal, oring and retainer, does anybody have info on installing this , torque on retainer and how does this hub vent itself, had pressure in it when i removed the check plug,thanks for your help
powertech84
11-30-2007 22:26:47
 Re: 8400 MFWD hub in reply to Greasey Hand, 11-27-2007 19:11:28
8400farmer said: (quoted from post at 01:11:28 11/28/07) Got 85-140 oil leaking out of front hub, got new seal, oring and retainer, does anybody have info on installing this , torque on retainer and how does this hub vent itself, had pressure in it when i removed the check plug,thanks for your help
before you dissasemble the retainer mark it with a center punch and count how many turns till its off. then put it back on in the same spot. done many of them this way and never had a single problem
joseph baxter
11-30-2007 12:41:29
 Re: 8400 MFWD hub in reply to 8400farmer, 11-27-2007 19:11:28
the hub it self is unvented if you are talking about the seal just on the hub it is not that hard to replace and there is no need for special tool but while you are in there you might think about replacing the bearings the only torque is a rolling drag on the wheel thighten the retainer untill wheel is kind of tuff to turn just not too much or you will have eairly bearing failure good luck
