How Hard are JD 420's carberators to fix?
BenGubbels
11-27-2007 17:41:07
My John Deere 420's carberator was flooding the engine.What causes this and how do I get it fixed? I am taking it to a mechanic If I can not get it fixed.
J. Chantry
11-27-2007 19:13:53
 Re: How Hard are JD 420's carberators to fix? in reply to BenGubbels, 11-27-2007 17:41:07
Ben, Rebuilding a carb is not that difficult. I've done an A, M, and a 40 with good results. Go to Roberts carb repair, they have good prices and fast shipping. Look under carb parts (link on left side) for listing of carbs, click on your carb, you will then see an exploded view of your carb. I diassemble the carb and soak in a gallon of carb cleaner for a week before I start rebuilding it. As far as flooding, many things can cause it (see archives) but it is probably a bad float valve or a leaky float. Shake float after you pull apart, if hear liquid you have a bad float.
Good luck.
Roberts - www.robertscarbrepair.com
