3020 Electrical questions
jefd
11-27-2007 09:35:48
I have a "65 3020 gas, 12V pos. ground system. I would like to add additional lighting but when the lights run too long, the breaker kicks out. What is the best way to add lights? Also, would a good option be to switch from a generator to an alternator? Thanks for your help
Gerald J.
11-27-2007 11:19:55
 Re: 3020 Electrical questions in reply to jefd, 11-27-2007 09:35:48
The current to the lights doesn't increase with time, but the temperature in the circuit breaker does and that eventually gets hot enough to trip.
While I like to see the generator as being original, Deere short changed the new generation tractors. I know the early 4020 generator was only rated at 20 amps, and that doesn't allow for adding many lights and still leaving enough current to charge the battery in less than half a day of running. As we use these tractors more for chores and run short times and add lights, that 20 amps can't keep up.
I have an alternator on my 4020. Battery life is much longer, and I've not needed the external battery charger at all (except the day the battery expired, then it wouldn't accept a charge either). Had to change to negative ground and that is claimed to mess up the gas gauge. You need to swap the coil polarity too.
And the new lights need (as posted below) to be on their own circuit breaker and relay. Automotive light relays are not expensive in any parts store.
Gerald J.
edj856
11-27-2007 10:07:06
What do you mean by "when the lights run too long"? A couple seconds or a couple minutes? If they stay on for a few minutes then the breaker kicks, check the breaker and the wiring. The amperage draw by the lights shouldn't increase the longer they are on. As for adding more lights, you can use the existing power to the lights to control an automotive type relay and run additional lights off the relay, with a circuit breaker, of course. Relays are normally rated at 40 amps which is more than enough for a couple lights. Cole-Hersee #RA-400112-NN for a 40 amp relay.
