Friends 70 Diesel
Kris A NC
11-27-2007 06:29:30
A while back a friend of mine was disking with a 70 diesel. It started to pull down and they pulled back on the clutch and it died. Flywheel was locked up and it wouldn"t start. They got it back to the shop, replaced the clutch and the clutch bearing and they were able to start it again. 20 minutes of running it at idle sitting still it pulled down again and died. Would this be the flywheel side bearing on the crank being shot, getting hot and binding up? Just curious. I am trying to help them if I can. Thanks
Kris A NC
Kris A NC
11-27-2007 13:25:58
 Re: Friends 70 Diesel in reply to Kris A NC, 11-27-2007 06:29:30
Thank you all for the advice. Like I said, this was for a friend so I will pass on the advice. They were talking in the same direction as that, but I just wanted to get your opinions on it since I was scratching my head. Thanks
Kris A NC
RobMD
11-27-2007 10:45:19
sounds like the mains are heating up and friction takes over the horsepower. Could be low oil pressure! Pop the pressure gauge line and see how much pressure you're getting with a numerical pressure gauge.
Of course, by now, you've already ruined the mains, so even if you fix the oil pressure, your engine will begin knocking.
Blksmok
11-27-2007 08:15:00
Kris...Mike M has pointed you in the right direction as to possibilities. Being it was running ok before and you had adequate crankshaft end play...I would guess a bad center main bearing or rod bearings. You can pull the pony engine off and check the rod bearings. Checking the main beaings is a much bigger deal. I wouldn't run it again until you've checked out the bearings.
F-I-T
11-27-2007 13:20:30
 Re: Friends 70 Diesel in reply to Blksmok, 11-27-2007 08:15:00
When ours tied up a center bearing with a piece of corn cob grit in it, you could not budge the crank using a large pipe wrench. Thankfully, it only rolled and smeared a bit of babbit from the bearing face .100" wide, but that was all it took to tie it up. Didn't have to turn the crank, but boy oh boy, it brought the ole' 70D to a screaching halt. Good news was, we bought a 4020D while the 70D was in the shop!
Mike M
11-27-2007 07:01:40
Does it have any crankshaft end play ? if too tight they can lock. Other than that it sounds pretty series and indepth like a spun bearing or something ?
