820 electric start batteries/battery box
toolz
11-26-2007 22:12:28
This old 820 I bought has been converted badly to electric start- just enough to go through the auction I think. It has the stock single battery box under the seat that holds one battery. Hardly enough to start it. How many batteries do I need, and what box? It has a solid mount seat. I saw a box on ebay for the sprung seat, but figured it wouldn"t work. Thanks again for your help. Kevin
Earl - IL
11-27-2007 18:25:48
 Re: 820 electric start batteries/battery box in reply to toolz, 11-26-2007 22:12:28
Kevin, I have the Deere electrical wiring book on both the 12volt & 24volt set up.If you need a copy give me a call. Earl S. In Mahomet
toolz
11-27-2007 18:18:08
Thanks for the comments. (55 50 I only go by one name). This tractor definately has some "issues", but I'm trying to make it useable again. I would prefer that it had not been messed with, but it is what it is. It was cheap- I couldn't justify the money a good one brings, and besides, someone should fix this one, rather than part it, so why not me?
I found out today that the starter is indeed 24 volt. I found another battery hidden under the operator platform on a homade bracket. Could just barely see it past the PTO. The starter is old and ugly, and I don't see a data plate yet. It has only 2 mounting bolts, and one of the ears is broken. I would prefer a 12 volt starter, if it would work. Any suggestions on what to use would be greatly appreciated.
Thanks again for your help. I'm new to the 2-cyl game, so I'm trying to learn all I can. Once I learn, maybe I can help someone else. Kevin
55 50
11-28-2007 09:20:15
 Re: 820 electric start batteries/battery box in reply to toolz, 11-27-2007 18:18:08
Sorry for my rather stupid remark before. You are to be given a pat on the back for saving this tractor from being parted out.
I don"t know if you can find a 12 volt starter that will work. Possibly all you need is a good 24 V starter with good mounting ears. A broken mounting ear (depending on how bad it is) might cause binding during a load. Are the cables of large size as suggested by Buickanddeere? A good starter and good heavy cables may be all you need.
kendak
11-27-2007 13:42:17
buckadeere hates a electric start 820 don't he...LOL...I'm going to use a starter off a 6 cyl. 8400 series JD...this is a gear reduction starter that has plenty of power to turn a 820..I have one on a 800ci. "G" ...my 820 has float ride seat & I will be using battery box off a "A" with [2] groupe 24 batterys...you can also put [1] battery under seat & [1] under hood where pony was with heat shield betwean it & exhaust...half the 830's made were ES & they are the same tractor as black dash 820...keep in touch...Kent
55 50
11-27-2007 15:00:51
 Re: 820 electric start batteries/battery box in reply to kendak, 11-27-2007 13:42:17
Sounds like "toolz" and "kendak" are the same person.
I don"t understand what relevance (to this subject) your side comment has, the one about "half the 830s made were ES & they are the same tractor as black dash 820".
buickanddeere
11-27-2007 14:21:01
Read again sunshine. I told him how to reduce his problems. And a warning to would be tinkerers that are on a budget and cost themselves more $$$ than what they save.
55 50
11-27-2007 08:30:09
Sounds like it may have been converted to a 12 volt starter. You say one battery, is it a 12 volt? Electric starts were 24 v with 4 six-volt batteries. Is that what you want to have?
The "stock" single batery box was for the 6 volt to start the cranking engine.
I think all 820s had the "solid" mount seat.
buickanddeere
11-27-2007 10:45:42
 Re: 820 electric start batteries/battery box in reply to 55 50, 11-27-2007 08:30:09
Two very large 12V AGM Optimas are less trouble than four sixes. Very large 00, 000 or 0000 cable with swagged on ends will be required. Depending on the starter motor used if it's a Delco 37,40,41,42 or 50MT. The smaller motors and some versions of the larger motors are under powered to crank an 820 no matter which batteries/cables are used. This tractor sounds like another classic where some tinkerer decided to save money & time. However they made the tractor operate poorer and reduced it's value. The tinkerer would have been farther ahead $$$ to not even have touched the tractor.
