4040 pto will not stay in
T Clark
11-26-2007 19:05:58
Looking at a 4040 Deere with 7300 hrs when you push the pto handle up it will not stay if you hold the handle up the pto will work like it should is this a simple fix or not
K.B.-826
11-26-2007 19:40:22
 Re: 4040 pto will not stay in in reply to T Clark, 11-26-2007 19:05:58
I take it that this is a quad-range or syncro transmission? If so, there"s a little potmetal arm inside of the clutch valve housing that operates the PTO valve. This arm is known to crack and not push the PTO valve down far enough to stay engaged. It"s a fairly easy job to replace if you"ve done one before. Also seen an out-of adjustment PTO linkage cause this problem.
powertech84
11-26-2007 19:25:03
could be simple. the lever is held engaged by a mechanism in the console that the lever goes over center. it could be out of adjustment.
