2010 getting water in combustion chambers
Benji Smith
11-26-2007 09:33:27
I have a 2010R diesel that I have completely rebuilt. The tractor runs good once started with ether. will not start with glowplugs. Noticed that once the tractor finally starts it white smokes alot until it burns all of the water out of the cylinders. Anyone have a idea where i should look. If anyone has experience with these tractors please feel free to give me a call. Thanks in advance. (864)608-1356
dlplost
11-27-2007 01:28:44
 Re: 2010 getting water in combustion chambers in reply to Benji Smith, 11-26-2007 09:33:27
You do have the operators manual don't you?
Proper glowplug times are:
Warm engine = 30 seconds
Above 32F = 1 minute
32F to 0F = 2 minutes
Below 0F = 3 minutes
I think Roy has it. Did you remove/reinstall the pre-combustion chambers during the rebuild? If so you must replace the washers etc, and torqued like Roy says else it will leak water into the cylinders. Even says so in the book. If you torqued all the chamber bolts the same, you'll need to remove them, replace the washers again and retorque the bolts properly to get it to seal.
When it starts properly you'll see white smoke just for a minute till all the cylinders are firing, then it should clear right up.
Roy Suomi
11-26-2007 18:25:34
The pre-combustion chambers are sealed with copper washers..The bolts that secure the chambers into the head are 2 different sizes.. [ least in a 1010 they are]..The bolts are torqued to 2 different values..They won't seal right if torqued the same..This will be one cause of coolant getting into combustion chambers..
Grant Walker
11-30-2007 12:25:15
 Re: 2010 getting water in combustion chambers in reply to Roy Suomi, 11-26-2007 18:25:34
Make sure the two water jacket thin pieces of pipe are used and are original JD. Some people think these are alignment plugs. What they do is protect the head gasket from the pressure and heat of the coolant. Without them, the head gasket will seep water between the coolant passage and who knows where.
dlplost
11-27-2007 01:12:41
Roy, the 2010 chambers are the same..
Pauls1010
11-26-2007 11:50:13
I think you need to verify a few things.
1. Are you sure the glow plugs work?
2. How do you know there is water in the cylinders? If there is water getting in there from the cooling system you have bigger problems than you may think.
3. Typicly white somke upon start-up is unburned fuel. The possible causes could be: glow plugs not working or low compression.
