'37 B Motor Troubles!
Chuck McDonald
11-26-2007 07:05:10
Good Week after Turkey Day All!
This summer my show "B" decided to have some internal bleeding going on. I am getting anti-freeze into my oil, but its not a massive leak, just steady. The motor is very strong and uses no oil, but I suspect that the push rod tubes are the culprits.
Since I have never disassembled this motor I have a few basic questions:
1.) The main location of parts that could be leaking are located in the Head correct?
2.) are guides also located in the block that could cause this leak?
3.) Where is a good source of guides/pushrod tubes for my unstyled B (SN: 39074)?
Thanks
Chuck
Rob in UPrMI
11-27-2007 16:55:41
 Re: '37 B Motor Troubles! in reply to Chuck McDonald, 11-26-2007 07:05:10
Pat is right, I just replaced mine in the 37 B I am currently restoring. They were $18 a piece from Deere. I bought mine in mid June. I had my head reworked, so the guy pressed mine out and put in the new ones. He said that 1 was very stubborn coming out. Hopefully yours will come out for you, Good Luck!!
Duane Larson
11-26-2007 19:11:25
Chuck,
An easy way to check the tubes for leakage is to park the tractor with the rear end higher than the front, pull the valve cover, and wait and see if antifreeze comes out of the front of the tube(s).
Chuck McDonald
11-26-2007 12:57:36
Thanks for all the info! Yall have been very helpful.
What will I see (other than milky sludge) when looking in the valve cover to know it is the tubes?
Chuck
Mike M
11-26-2007 13:17:19
 Re: '37 B Motor Troubles! in reply to Chuck McDonald, 11-26-2007 12:57:36
You likely will see it (antifreeze) beaded up right by those tubes and a trail down from them.
Kendog
11-26-2007 08:16:39
Chuck, I just went through this repair (re-assembled the head yesterday) and should have a good photo of leaking tubes for you. Send me an email; [email protected] and I'll bounce some info back. -Ken
Mike M
11-26-2007 08:04:07
Very easy to pull off the valve cover and have a look. When mine were leaking it was easy to spot that it was indeed those push rod tubes once the valve cover was off. And I replaced them with the cyl. head still on.
P Browning
11-26-2007 07:23:06
Chuck -- shoot me an email. I have an excerpt from a field service bulletin that will answer your questions 1 & 2. (Cylinder Head). These tubes (sleeves) can be renewed without removing the cylinder head if you are a bit resourceful.
They remain available through your JD Ag Dealer at a cost of roughly $20 each -- there are four of them, and if renewing -- I recommend renewing all of them! Original part number is AB1284R now replaced by current part number B1290R. (PatB)
