FIT and Paul in Wi., RE JD 955
Baelee05
11-26-2007 03:57:03
Thank you both for your input on the 55 series Deere compacts. I will look into your suggestions. Paul, if you could post some pictures of your setup that would be great. Thank you much.
Paul in WI
11-26-2007 18:42:34
 Re: FIT and Paul in Wi., RE JD 955 in reply to Baelee05, 11-26-2007 03:57:03
I got your post. I will get some pictures tomorrow. Paul in WI.
Mike M
11-26-2007 05:23:42
I went back and read your post. Let me add something nobody else mentioned. How long ago since your valves have been adjusted and your injectors tested ? I'm thinking Deere says do it every 500 hrs. The first time you will get some on the valves and later on the injectors will need worked on and even new tips. My pump shop says to keep a close eye on those Yanmar injectors. Also new air filter and fuel filters all this will cut down on the amount of smoke. Hiway fuel will too.
Baelee05
11-26-2007 06:30:31
 Re: FIT and Paul in Wi., RE JD 955 in reply to Mike M, 11-26-2007 05:23:42
Thanks Mike. The tractor only has 790 hours on it so there is a real good possibility that the valves and injectors have never been touched. I will check both of these things out.
