8.1 cylinder head on a 466?
DRC
11-25-2007 18:24:35
will a cylinder head from a 7810(8.1L) fit on a 466 engine in a 4440?
rexhellwig
11-25-2007 20:23:37
 Re: 8.1 cylinder head on a 466? in reply to DRC, 11-25-2007 18:24:35
It will bolt to the 466 block, but that is just the beginning.
The 8.1 uses larger valves. They may {or may not} clear the reliefs in the top of the 466T pistons. If they don't clear. You'll need a set of 7.6 pistons to match the head. But they won't fit your 466 rods, so you'll need a set of 7.6 rods too.
Let's pretend the head fits and clears the 466 pistons OK. Your 466 injectors won't fit in the 8.1 head, so you'll need to come up with a set from a 7.6 or an 8.1. ... But are they "aimed" to fit the bowl of a 466 piston? Don't hold your breath waiting on that information from the factory guys.
And last. Will the engine start? The 466T valves protrude down into the chamber, while the newer heads use recessed valves. {compression will be lower}
Unless you're making some kind of puller, stick with the readily available original head.
DRC
11-26-2007 07:36:45
 Re: 8.1 cylinder head on a 466? in reply to rexhellwig, 11-25-2007 20:23:37
Thanks for the reply. Yeah I am considering making a pulling engine. I came across a 466 with a spun rod bearing and I also have a head lying around off of a 7810. Just thought the newer head might breath better.
