1010 followup
clint evans
11-25-2007 15:30:44
Thanks for all the info so far from everyone. What does the R stand for on the ID tag? It has no U just an R. Serial # is 54279, is this a 1965 model? This 1010 has 36 inch rear tires, and a very slow 1st gear like not even 1 MPH. Is this normal? The books I have read list the 1010 and 2010 at 2.65 MPH low gear.
Grant Walker
11-30-2007 10:33:34
 Re: 1010 followup in reply to clint evans, 11-25-2007 15:30:44
Later versions, I think serial number 4,000 and up had a lower gear rear end. Check out 1969 edition of Green Magazine. I don't know which month. It was an anniversary article on the 1010.
Grant Walker
11-30-2007 10:31:43
R = Row crop
U = Utility, special
Pauls1010
11-30-2007 09:33:25
Ok, its an R with 36 tires. I'll check it out tonight for you. It may be 1 5/8 mph.
Pauls1010
11-26-2007 11:55:58
My '64 1010 gas RUS model has the 28" tires also. 1st gear is about 1-2 mph at most. I have a book with all the specs for R. RU. RUS models, including orchard models. I will look up and see what you should have for tires if you like.
clint evans
11-26-2007 16:38:49
 Re: 1010 followup in reply to Pauls1010, 11-26-2007 11:55:58
Pauls 1010, if you don't mind I would like to know what the ground speed is suppose to be. The working tach says 1.5 at highest RPM.
Paul1010
12-01-2007 06:13:40
 Re: 1010 followup in reply to clint evans, 11-26-2007 16:38:49
Clint..... your model specs show 1 5/8 mph at 2500rpm.
Pauls1010
11-30-2007 09:30:33
Your looking for ground speed in 1st gear?
They list the speeds by gear and RPM, 1000, 1500, and 2000-2500. AND by tire size
4020LP
11-26-2007 06:29:32
And yours is the diesel, right? A 1010 Row-Crop (R) would have had 36" rear tires, and only 273 of them were built with diesel engines. With the exception of the Agricultural Crawler and the Orchard, you have one of the rarest diesel 1010's. Best of luck to you with it!
clint evans
11-26-2007 16:36:36
 Re: 1010 followup in reply to 4020LP, 11-26-2007 06:29:32
Thanks for the info 4020LP. This is a real nice original tractor with only 1675 hours on the working tach. Sheet metal is very straight even has the original working lights. Still has most of the paint, but could stand to be repainted. It starts and drives great. I don't know what I will do with it, perhaps just keep it around for light tasks...
4020LP
11-26-2007 19:18:49
 Re: 1010 followup in reply to clint evans, 11-26-2007 16:36:36
Which it will do just fine. Really, by the time your 1010 was built, the bugs were out of them. No, it wasn't Deere's best design, but the 1010 wasn't appreciably worse than anything else in its time. Having a low-hour original tractor is a great thing to have these days, have seen them bring more than freshly painted tractors. Take good care of it, and it'll take good care of you down the road. Get an Operator's Manual for it, and do what it says, and you'll be surprised how few problems you'll have.
Osage
11-26-2007 05:59:45
Clint:
According to the Tractor Data web site the serial number range for the year 1965 was 53722 - 57312, so yes your's is a 65'.
Mine has a serial number 57085, which is quite late production, as some would say its probably made from leftover parts, but she runs good.
From everything I can find the 1010's normally had 28" tires, as does mine.
Osage
Roy in georgia
11-25-2007 15:56:27
the R stands for row crop. is that the only letter on it mine is a 65 RUS (row crop utility special)
