JD 955 Compact
Baelee05
11-25-2007 06:35:08
I know this isn't exactly an antique tractor issue but thought maybe someone could help. I recently bought a JD 955 compact tractor with 70a loader. I'm pretty impressed with the machine so far. The only thing that I don't like is the fact that the exhaust which exits on the lefthand side shield blows right back on you especially if going into the wind. Did Deere make an add on exhaust kit to elbow this exhaust at the shield and then bring it straight up along the hood with a straight pipe? Other than that I really like it. I just don't like sucking up all that exhaust. I think I'm going to have purchase or fabricate a grill guard to prevent damage to the front end when using the loader for certain things. I would appreciate any comments that you folks might have on this unit. Anything to watch out for or anything you really like about them. The dealer did tell me that they were more reliable than some of the units that replaced them. Thanks for any help.
F-I-T
11-25-2007 09:05:42
 Re: JD 955 Compact in reply to Baelee05, 11-25-2007 06:35:08
I have an 855 and I have told many people that, IMHO, of the tractors that I have owned, and that goes from as early as a GP to a 70D to 4020D to as late as a 4440 restored from a cab fire, that for it"s designed purpose, the little -55 compact tractor is the best John Deere that I have ever owned. They do no not like to run hot, so if you do, fast idle in the shade to cool them down before you shut them down so it doesn"t suffer from heat soak.
The early type 855 and 955 routed the smoke through a hole in the left side shield, but the later ones routed the pipe out below the exhaust shield and that diverted the exhaust much better. You could install the newer pipe, and patch the hole in the side shield if you like, or route the pipe under and have it blow on the ground, or through an extended slot along a length of tube, or out the top. I"ve decided to let mine go out the bottom and works pretty good. I don"t get much smoke unless I am pulling it pretty hard and that does not happen to often.
If the loader is like the 70 loader I have on my 855, it should have a basic grille guard surrounding the front grille. I have seen others install open-weave mesh or expanded metal, or simply weld on some 3/8" or 1/4" rod to form a grille guard, but I have not had any issue with "stuff" getting by as it has to go quite an end to pass the bucket and get to the grille. By that time you should probably have stopped.
Maintain the front end mechanical wheel drive gear sets as outlined by the book. Those were probably the weak point if any, and it"s cheap insurance to keep an area like that lubed up.
I"m thinking of buying a 955 myself and using it for the loader work and installing a small backhoe, keep ing the 2wd 855 for lawn mowing only. They are nice, easy to use machines.
Frank
Paul in WI
11-25-2007 08:37:14
I had the same issue with my 855. I took it to a muffler shop and had them fabricate an exhaust that goes under the side shield the then straight up to the same hieght as the ROPS. I had to fabricate my own mounting of the exhaust pipe. Up near the radiator I fastened a piece of flat steel to come out between the hood and the front grill top. I had to notch the hood a slight amount. Since the engine is on rubber isolators you cannot rigid clamp the exhaust pipe so I used a rubber isolator, you know the kind that has a stud on each side. I can send or post picture if you want. Paul in WI.
