4455 powershift slipping
i have a broke
11-24-2007 18:31:40
my 4455 powershift slips in most of the gears mostly above 10th gear what is rong with it, it only has 1500 hrs on it.
powertech84
11-26-2007 15:33:50
 Re: 4455 powershift slipping in reply to Lyle Pfeifer, 11-24-2007 18:31:40
eatwell69 said: (quoted from post at 17:24:08 11/26/07) I used to be a mechanic at a John Deere dealer and had this problem once. It turned out to be a bent arm on a shift valve that bolts on to the side of the transmission. I remember this because it took a week of testing and taking this tractor apart and putting it back together before I found the problem.
i see those arms in the traction valves bend on the 30 series quite frequently, mostly pto, but i've never seen it on a powershift, or a newer tractor. should be easy to test for though, just stick a gauge on c1 and push the clutch in and out.
Marlin Fultz
01-27-2009 11:26:52
 Re: 4455 powershift slipping in reply to powertech84, 11-26-2007 15:33:50
On a John Deere 4455, powershift slips in all gears above 11th.
I ran some pressure tests on the transmission. They seem to really vary. C-1 pressure is 110 PSI, C-2 is 120, C-Low is 190, B-High is 190, B-4 is 190, and C-3 is 185.
Are you able to help me with this slippage?
Thanks in Advance!
eatwell69
11-26-2007 11:24:08
 Re: 4455 powershift slipping in reply to i have a broke tractor, 11-24-2007 18:31:40
Tx Jim
11-26-2007 04:14:55
 Re: 4455 powershift slipping in reply to PeavyTx, 11-24-2007 18:31:40
powertech84 my mistake about torque dampner as I left JD dealer for farming in '87. As for what psutfg11 brought up about hours if original posters 4455 has a digital tach as my 4255 does it would take a computor geek to alter hours. I agree about 55 series tractors as being good ones. Tx Jim
psutfg11
11-25-2007 20:50:27
a 4455 with the powershift slipping at 1500 hours? im guessing it has 11,500 hours. i have three 4455s,2 of them bought new,all have at least 8,000 hours. 1 has 10,400 and the trannys havnt been touched on any of them. we maintain ours regularly,that is the key to everything. 1 thing to think about,that is very low hours (if correct)for an at-least 15 year old tractor. makes you wonder if it was built on friday the 13th. i love my 4455s and would never trade them,definitely 1 of the best tractors ever built. hope you find the problem.
Tx Jim
11-25-2007 04:51:04
 Re: 4455 powershift slipping in reply to THOMAS M. MCBAIN, 11-24-2007 18:31:40
I agree on hyd testing but the dampner clutch could also be slipping. Tx Jim
powertech84
11-25-2007 07:21:21
 Re: 4455 powershift slipping in reply to Tx Jim, 11-25-2007 04:51:04
dampner clutch on a 55 series? c1,c2 takes the place of the dampner clutch on the 19 speeds
powertech84
11-24-2007 20:12:27
youll have to do hydraulic testing to know for sure
