51b
daninsc
11-24-2007 13:33:09
on a 51 b i'm looking at buying there is another level 3 inches under the throttle lever. the guy said it was for the shutters but isn't hooked up and there are no shutters on the tractor, did some models have these or a 51 did have these or maybe this part got swapped, please let me know what you think.
B-maniac
11-25-2007 18:13:38
 Re: 51b in reply to daninsc, 11-24-2007 13:33:09
All had them when new. Most rusted up , linkeage either rotted off or was removed.
jdjerry
11-25-2007 07:44:10
I have 3 or 4 shutters in the back of the shed that came off my grandfathers tractors. They were off of all fuel tractors. I have a couple of A's and a B that are gas tractors and I don't think they ever had shutters on as there are no linkage parts on them but I never have looked under the hood close to see either.
machinery-man
11-24-2007 14:50:21
I've had them with and without shutters. Gas tractors if used with shutters would experience some restriction through the shutters, that's why they were removed. Even open they presented some blockage. Bigger problem for the B's is intake throat icing....side curtins will solve this...
4020LP
11-24-2007 14:20:21
All styled "B" Tractors were equipped with shutters from the factory. The advice from the posters below is very good and more people would have less problems if it was heeded.
B_Bob
11-24-2007 14:08:41
I've got a 50 B with the same deal - no shutters but has the linkage. Don't necessarily need the shutters but may add to the value and you can find them on ebay. Also have a 40 B with shutters. They were stuck so I removed, cleaned up, and reinstalled them and they work like new. Makes the tractor complete.
Buy the tractor with or without shutters - you won't regret it!
Bob Collins
11-24-2007 13:54:44
I think they all came with shutters, they were very important on all-fuel tractors to keep engine temp up, but the gas tractors were not as fussy. When they became clogged, stuck or in the way of radiator repair they often got discarded with just the operating lever and some linkage remaining. Keeping engine temp up is to your advantage to reduce the amount of vaporized fuel that "drops out" of vapor and washes oil from the cylinder walls, warm engines are less likely to foul spark plugs too.
