Mike M ?
THE SMOOTHED DE
11-24-2007 11:09:57
What models of cultivators will fit on my 48b ? Will they mount with the flat top fenders on ?
J. Wondergem
11-24-2007 15:41:21
 Re: Mike M ? in reply to THE SMOOTHED DEERES, 11-24-2007 11:09:57
When I was a kid, we had a 36 "B" with manual lift cultivators with flat tops on. The nieghbor had a 46 "A" with power lift with flat tops. My neighborhood everyone ran fenders.
Mike M
11-25-2007 10:22:00
 Re: Mike M ? in reply to J. Wondergem, 11-24-2007 15:41:21
You wouldn't happen to be in Michigan would you ? I heard that state had a law that required all tractors sold to have fenders.
J. Wondergem
11-26-2007 18:08:24
 Re: Mike M ? in reply to Mike M, 11-25-2007 10:22:00
Yup, Michigan. I don't know about any law saying so, but a tractor without fenders was a Southeren tractor. This was back in the early "50's".
J. Wondergem
11-24-2007 15:45:37
Another neighbor had a 51 "A" power lifts, and clam shells.
Mike M
11-24-2007 15:16:28
I will just have to agree with the others as I don't have first hand knowledge of what model those cultivators were I have seen on them. Very few tractors had fenders in my area back in the day when they were used. Are you looking for a set ? If so I can beat some bushes and see if I can turn up any. My cousin may have some if we can talk him out of them. I am about 70 miles north of Columbus Oh. I was thinking you were south of here ?
THE SMOOTHED DEERES
11-24-2007 17:29:29
 Re: Mike M ? in reply to Mike M, 11-24-2007 15:16:28
I am interested in getting a set ! From what i understand my tractor was used years ago with a set of two row mounted cultivators . I have the front bracket and the knobs on the sides of the frame for mounting already on tractor. My other question would be do people have problems fitting these on trailers when there mounted ? I'm cutting it close just getting the tractor on the trailer width wise so u can see my concern .I'd like to display it mounted ,and i would smooth it out . I'm about 2 and half hours away , shouldn't be a problem for the right set .
Mike M
11-25-2007 12:10:27
 Re: Mike M ? in reply to THE SMOOTHED DEERES, 11-24-2007 17:29:29
I called my cousin and he is checking. He doesn't think he does but maybe a neighbor does. I don't think width on the trailer will be a problem,but rather loading it could be ? You may not have enough height to clear when you go up the ramps and over a beavertail if you happen to have that kinda trailer. I do have a 3 point and 2 types of fenders that will fit that tractor. My email is open.
RobMD
11-24-2007 11:17:20
The cultivators I had on a b was the ABG 200? series? Not sure about the fenders
B-maniac
11-24-2007 13:47:19
 Re: Mike M ? in reply to RobMD, 11-24-2007 11:17:20
The A/B/G 200 series "quick-tach". I'm not sure but what the depth adj. levers might use the same studs on the front of the axle hsng. as those fenders mount to. On the newer square axle B's the fenders bolt directly to the top of the housing and that leaves the one set of studs on the front for the levers. If there are an inner and outer set of studs on the front of your axle then probably the fenders would mount to the outer set and the levers to the inner set. I'm sure i have seen the cult. and levers on rount top fendered B,s with fenders on.
