810 vs 415A plows
SMinWi
11-23-2007 18:34:13
Can someone here tell me what makes them different?
ET
11-26-2007 09:24:21
 Re: 810 vs 415A plows in reply to SMinWi, 11-23-2007 18:34:13
The 415 plows seem to all have catagory 1 hitches but may have been available with catagory 2 also. The 810 and 810A plow has a shortened beam on the front where the coulter for the front bottom mounts. The front coulter shank on these plows had a longer offset to get the coulter out in front of the bottom for trash clearance. The reason for this setup is when the 20 series tractors came out the valve box for the remote cylinder was on the right rear of the tractor and the plow frame would hit the valve box if it was not shorter. I have some old dealer information about cutting the piece off on 812 and 813 plows and using the diffrent shank to retrofit to the new tractors. The 415 plows still have the longer frame for the regular front coulter shank. Over the years a regular coulter shank has been stuck on many 810's when the origonal got bent or smashed.
Bob Collins
11-25-2007 17:00:27
After examining all the literature and catalogs I can find, here is my last reply: They look to be nearly identical in the brochure pictures but the specs list the max. plowing depth of the 415 as 10 inches with 24 1/2 inches of vertical clearance. The 810 max. depth is listed as 12 inches but I can't find a clearance figure. The literature clearly states all 810 plows except the 4 bottom will fit current John Deere 3 point hitches and earlier John Deere tractors with 800 series hitches. 411, 415 and 416 plows are for 330, 420, 430 and 435 and similar small tractors with standard 3 point hitch. Both models APPEAR to have cat. 1 hitch from photos which is not necessarily reliable. I think having the 2 "side by each" would be the ideal solution.
Bob Collins
11-24-2007 13:59:48
My understanding is the 810 and other 800 plows were designed to attach to the 800 and 801 hitch on A-B-G tractors. The 415 was later and designed to be used with 40 series Dubuque and similar size tractors.
SMinWi
11-24-2007 17:25:27
 Re: 810 vs 415A plows in reply to Bob Collins, 11-24-2007 13:59:48
No the 810 was new in 1957 so it's to new to be the age of the 800 801 hitch
Bob Collins
11-25-2007 15:52:10
 Re: 810 vs 415A plows in reply to SMinWi, 11-24-2007 17:25:27
SMinWi: My info shows the 810 starting in 1956, but you are right, that still makes it too new to be designed for the 800 hitch. Maybe someone who knows the answer to the original question will reply. Bob
SMinWi
11-25-2007 17:16:50
 Re: 810 vs 415A plows in reply to Bob Collins, 11-25-2007 15:52:10
I think the 812 or 813 were for the 800 801 hitch.
BlaineM
11-24-2007 11:43:37
The first thing that comes to mind is that 810 is a cat.2 and 415A is a cat.1
SMinWi
11-24-2007 13:51:43
 Re: 810 vs 415A plows in reply to BlaineM, 11-24-2007 11:43:37
I'm not to sure about that. The 810 i looked at today has cat 1 pins. Yes i'm sure it's a 810
