Hydraulic pump assembly question
Kurt_JDB
11-23-2007 18:06:28
I am in the process of rebuilding a "live" Hydraulic pump for my "51 B. I am ready to reassemble the pump. The JD hydraulic service manual states that the faces of the pump body should receive a thin coat of shellac before assembly.
Are they talking about using something like indian head gasket shellac? Seems like it might be hard to get apart again. The pump did not seem to have been put together with it when I took it apart.
I would like some opinions about what to use on the pump faces before assembly.
Thanks,
Kurt
F-I-T
11-23-2007 19:14:52
 Re: Hydraulic pump assembly question in reply to Kurt_JDB, 11-23-2007 18:06:28
Indian HEad or equivalent is what they meant. It's on the shelf at NAPA and Discount Auto Parts around N.Florida.
I like to lap the pump body faces so that they could wring in without it. You'll be guarabtedd that they are dead flat that way. There always seem to be high spots around the bolt holes.
Kurt_JDB
11-23-2007 19:40:52
 Re: Hydraulic pump assembly question in reply to F-I-T, 11-23-2007 19:14:52
Thanks,
I keep A bottle or two of Indian Head on my shelf all the time. It's what I use for most of my gaskets. Do you lap one face against the other after pulling out all the studs etc? I used to be into grinding and polishing telescope mirrors, and we would always use two mirror blanks. One would become the "tool" and the other one would be the mirror.
Kurt
F-I-T
11-24-2007 05:42:01
 Re: Hydraulic pump assembly question in reply to Kurt_JDB, 11-23-2007 19:40:52
I finish lap them together, but to get them close first I use an old 1'x1' soft steel plate that I milled a cross-hatch pattern into years ago.
