3020 3pt all or nothing
dssb4
11-23-2007 11:57:49
The 3 pt on my 3020 will only raise if I put the lever all the way up. It will pick up the implements, but has trouble holding them in any setting other than all the way up or all the way down. New hydralic pump. Is there some other valve to check or replace? JD said it needed a new pump, which made no difference whatsoever after paying them big $$$$$$$$$$$$. Their mechanics don't want to work on these "antiques", so I'm on my own.
Tx Jim
11-24-2007 03:48:26
 Re: 3020 3pt all or nothing in reply to wilamayb, 11-23-2007 11:57:49
dssb4 the JD dealer that told you the main pump was your problem doesn't know squat. As the others have already stated adjust your L/D according to specs which is lengthy but should fix your problem. Tx Jim
msb
11-23-2007 17:27:20
 Re: 3020 3pt all or nothing in reply to dssb4, 11-23-2007 11:57:49
Check the archives. I recently posted the proceedure for making the adjustment.
mattd
11-23-2007 12:33:03
have you tried to put the draft lever in a different position to see if it makes a difference. somthing in your draft control linkage may be broken or way out of adjustment. when the control lever is all the way up system pressure is open to the lift cylinder which is why it only hold when the lever is all the way up. your valves may be worn out and leaking really bad. i suggest getting a tech manual and go through the draft adjustment procedure if that doesnt work remove your control valve housing and go through it, look for worn linkages and damages o rings. then be sure to adjust the draft linkage again. i guarantee almost all 10-20 series draft is out of adjustment
