46 B issues
patsdeere
11-23-2007 11:55:46
I was driving the machine around yesterday and came across 2 issues I have never heard of or seen before.
1. When I snap the clutch out the clutch disc somewhat bounces around and makes a lot of noise. Is the pressure plate too loose? There is also a wierd feeling when I push the clutch rod forward it seems like it goes further than it should and there is a rumble noise. It goes into gear without a problem, but it just doesn't feel right.
2. Out of the exhaust relief valve there is a bunch of oil that keeps getting sprayed out from around where the lever part goes in. I put on a few extra washers to get it tight and it didn't help. The handle is now touching the main part of the valve. Do I need to replace it or can I build it up and then lathe it back down to where it fits tight?
Jason R
11-24-2007 07:15:09
 Re: 46 B issues in reply to patsdeere, 11-23-2007 11:55:46
Pat, You may want to check the tightness of your clutch driver on the crank. It may be loose or the crank splines may be worn and the driver loose. Best thing to do is to open it up. As far as the compression valve, I would buy a new one from Deere.
