Correction- the disk is a BWF. Any info?
farmerboy
11-23-2007 08:48:56
Turns out the disk I bought is a BWF. From my understanding, it is similar to a BWA but it has spring cushioned gangs. Mine has 6 bolt hubs. Anyone have any experience with this disk? Is it a good disk for finishing? Looks to be heavy enough to use as a cutting disk if I wanted...
Tx Jim
11-25-2007 05:09:28
 Re: Correction- the disk is a BWF. Any info? in reply to wilamayb, 11-23-2007 08:48:56
The 220 series were notorious for breaking the frames. JD replaced many frames in and out of warranty. They plowed decent and would leave ground level if one could keep frame together!!!!! !
msb
11-23-2007 17:32:45
 Re: Correction- the disk is a BWF. Any info? in reply to farmerboy, 11-23-2007 08:48:56
Bought one new in the late 60s. F stands for flexible or flex. Not a really bad sort on a disk if you don't mind folding it up all the time. Better than the 220 that I bought next and MUCH better than the AW that preceded it.
farmerboy
11-24-2007 05:12:50
 Re: Correction- the disk is a BWF. Any info? in reply to msb, 11-23-2007 17:32:45
Hi MSB,
In fact, this one is replacing an AW. That AW sure is a rotten disk. I thought it was just cause ours is shot, but if yours was no good as well they musta all been bad. Shouldn't hafta fold it up all that often as our ground is all in one piece. What was bad about the 220?
Gerald J.
11-23-2007 10:04:11
I've only used my BW as a finishing disk. I've mounted a couple bars of spring tooth harrow (from a planter) on its rear. Used to take two passes (first one at 6 mph, second at 9 mph) to level off my plowed field and make a good seed bed. Took three passes without the harrow. Going at those speeds flips the little weeds up in the air so they die quickly.
Gerald J.
farmerboy
11-24-2007 05:04:44
 Re: Correction- the disk is a BWF. Any info? in reply to Gerald J., 11-23-2007 10:04:11
Hi Gerald,
You mentioned you might have the locks in your scrap heap on the last thread. Is there a chance you'd be able to find them and snap a picture for me? I might buy them if you wanna get rid of them.
