2510 rewiring coil and external ignition resistor help need
JWR991
11-22-2007 18:27:41
I have a JD 2510 Gas about 2 weeks ago I had a dead short in the wiring harness and melted the wiring from switch harness to the engine harness. I ordered a new harness from Agri-Services in New York. I recieved it this week. Not knowing what caused the melt down I decided to change the Alternator and coil. The coil came from John Deere. On the coil its says 6V coil no external resistor required. On the new wiring its says The harness requires an external igntion resistor. I believe the original harness had resistor wire built into the wiring harness so the external resistor would not be required. My question is does the OEM replacement coil take into account the original wiring setup and do I really need to resistor to step down the voltage? My current plan is to add the resistor.
jdemaris
11-23-2007 07:05:41
 Re: 2510 rewiring coil and external ignition resistor help in reply to JWR991, 11-22-2007 18:27:41
Are you sure the dealer sold you the correct coil? It's supposed to be the same coil as used in the 420, two-cylinder gast tractors and it is 6 volt (with no internal resistor). It is needed with most Deere gas tractors of that generation of they don't start when it gets cold.
The original setup used a resistor built into the key switch. Then, Deere updated to a separate switch and resistor, and later tractors used a resistor wire instead. If it was mine - I'd make sure it's the OEM 420 6 volt coil, I'd install an external ballast resistor, and wire the bypass off the "R" terminal from the Delco starter. That's the best and easiset way to do it. Deere didn't - because not all their starters were Delco at the time - some were Prestolite with no R bypass.
JWR991
11-23-2007 09:16:34
 Re: 2510 rewiring coil and external ignition resistor help in reply to jdemaris, 11-23-2007 07:05:41
I am sure its the right coil. What I matched it up on myJD parts and then rechecked it after I got it. What threw me was the statement on the coil saying no external resistor required. At this point I am adding the resister it should arrive today or Monday.
JWR991
11-23-2007 09:16:29
Bob
11-22-2007 18:35:27
Is the system 6-Volts or 12-Volts???? (I certainly would think 12-Volts?)
6 Volt battery... follow the instructions on the 6-Volt... coil NO resistor.
12 Volt battery... You MUST use a ballast resistor to use the 6-Volt coil. If the wiring harness is set up with a resistor bypass wire from the starter solenoid terminal marked "R", this setup will be a GOOD choice.
If you are NOT going to use the ignition resistor starting bypass circuit, you may as well simply get a REAL 12-Volt coil, such as a NAPA 14SB, and ELIMINATE the need for the ballast resistor altogether.
JWR991
11-22-2007 18:42:40
 Re: 2510 rewiring coil and external ignition resistor help in reply to Bob, 11-22-2007 18:35:27
The 2510 is definitely 12 negative ground according to JD service manual the original harness had a resistor which stepped the voltage down to 6 volts for a better spark.
RobMD
11-22-2007 18:31:30
You have to add the resistor to get the voltage down to 6 volts. Sometimes i have seen coils that say 12 volt external resistor required. They want the voltage to be 6 volts at the coil. In your case, I am thinking you can go ahead and hook it up.
