2150 hydraulics
T. G. [GA]
11-22-2007 15:08:36
When raising the loader the three point hitch will drop. What could be the cause? and is this a common problem with this model JD.
Holz Equipment Service
11-22-2007 18:16:16
 Re: 2150 hydraulics in reply to T. G. [GA], 11-22-2007 15:08:36
One question; does this tractor have an add-on hydraulic control valve for the loader? I found this same problem several years ago on a JD 1530, someone had installed an open-center valve instead of the closed-center type needed. After we converted the valve to closed-center, the problem was corrected. Good luck
buickanddeere
11-22-2007 15:48:37
Is there any weight on the three point hitch such as ballast? Does the three point hitch settle with time when the tractor is at rest? Have a boo in through the oil filler with a high powered flashlight while the engine is running and no hydraulics being operated. Any sprays, drips etc coming from the top of the transmission case/rockshaft body? The three point should at max height and then also at normal working height during the viewing. How is the loader plumbed into the tractor?
