2010 cooling issues / three point lift ( HELP)
swagbanker
11-22-2007 03:11:36
I being working on a 62 2010 diesel, giving it a little TLC so to speak. Had radiator(it had crack at top of radiator) repaired, replaced hoses(two and now the water pump hose hole) and still have pressure building up at cap. After putting radiator back on tractor, filled up coolant and it appeared that water was circulatings, by the way the water was moving at radiator cap. From what I can tell, it is building up WAY TO MUCH pressure. I cranked it last night, temp was 45 outstide, - today I drove down to get a bale of hay and it started overflowing(from radiator top) after driving for 5 minutes. I have ordered a new thermostat and radiator cap, to try that. How do I check to see if the water pump is actually working correctly? any help would be greatly appreciated. Additionally, a few months ago I cleaned the hyd filter and new fluid. Worked good after doing so, today-when I tried to lift the bale of hay, it would only do so about 1 ft. Drove off with it, and after 2 minutes of driving, the bale lifted all the way up. Do you think I need to put a new filter (If so, where can I find a 8 inch after market filter) or does the 2010 hay issues lifting a 1100 pound round bale of hay. any help would be greatly appreciated.
turklilley
11-23-2007 07:22:55
 Re: 2010 cooling issues / three point lift ( HELP) in reply to swagbanker, 11-22-2007 03:11:36
Those Hydraulic Filters are hard to clean, Parts cleaners don't work. I used a ultrasonic cleaner with some success. Industrial soap will work if you soak them a few days. That is probably the problem with the hitch.
Tx Jim
11-23-2007 04:18:55
 Re: 2010 cooling issues / three point lift ( HELP) in reply to JDAOS, 11-22-2007 03:11:36
I would have a chat with radiator repairman!!!!! One can put a gauge on radiator neck to check pressure. I don't know correct psi but I think it would be in the 7-15 lb range. Only other way would be have head magnifluxed. Tx Jim
Tx Jim
11-22-2007 03:53:10
 Re: 2010 cooling issues / three point lift ( HELP) in reply to JDNPC, 11-22-2007 03:11:36
On cooling issue it probably has a cracked head as 2010 diesels were notorious for that to happen. I think a 2010 should be able to lift a rd bale with ease. Sometimes those filters(screen) require replacement and as far as I know mother Deere is the only source. Tx Jim
swagbanker
11-22-2007 20:19:34
 Re: 2010 cooling issues / three point lift ( HELP) in reply to Tx Jim, 11-22-2007 03:53:10
It was fine until I had to have the radiator repaired. (On the cooling issue) The lift picks up the shredder fine and has been working good.
On the Head Issue, how to test>?
