46 B
patsdeere
11-21-2007 20:31:58
Whoooppiiee - I got it to run today.
I did run into 2 small problems.
1. When I hooked up my battery the lights don't work when I pull out the switch. The bulbs are new and I just put the lights back together (if that makes a difference).
2. Even though the carb is supposedly set right(?) I can't get it to run on anything less than 1/2 choke.
Another question. On my front wheel (I have the BN model) there is a hole in the side of the fork that is supposed to have a screw in it. What I can't figure out is what it screws into, what exactly keeps it from comming out and what it is for.
Thanks for all the help.
Happy Turkey Day all.
DanL-Colorado B36320
11-24-2007 18:39:26
 Re: 46 B in reply to Gary from Muleshoe, 11-21-2007 20:31:58
As you look at the mag, CW will retard the timing, CCW will advance it.
Place the flywheel on the timing mark with the left cylinder on the compression stroke. Loosen the bolts on the magneto and rotate it CW as far as it will go; then rotate it CCW until the impulse trips. Tighten it at that point. At least on my unstyled 37, that's the procedure, probably the same for yours.
patsdeere
11-23-2007 22:51:23
 Re: 46 B in reply to patsdeere, 11-21-2007 20:31:58
I was just thinking, could the idle problem possibly be associated with the timing of the mag? I simply put it on and bolted it up tight and somehow got it lined up so that the left cylinder fires exactly when the mark on the flywheel is at 3 o clock. If it could be the mag, which way would I turn the mag (towards the front or the back)?
Thanks.
DickD
11-23-2007 05:53:48
I ran into this situation, and had to replace the intake manifold gasket. If this happens to you, be sure to use a straight edge on the head, and manifold surface. Another place to look.
P Browning
11-22-2007 01:37:34
On your 1/2 choke issue, go to the JD-H restoration site (below), scan across to ARTICLES 1, drop down to CARBURETORS, and on page 9 of that piece you will find a no-wrench test to perform on your carburetor. 'Sounds to me as if a segment of the IDLE path could still be blocked.
CalJim
11-21-2007 22:16:33
That hole on the right side of the yoke is for a bolt that holds the lock plate up against your axle nut.(keeps the nut from backing off) You might want to check a parts book. CalJim
patsdeere
11-22-2007 11:05:05
 Re: 46 B in reply to CalJim, 11-21-2007 22:16:33
I have a parts book and looked in it. I figured it had to keep that disc thing from backing out, but don't remember seeing a way to keep the screw in. I will double check the book. The fork isn't threaded is it?
P Browning
11-22-2007 11:28:00
 Re: 46 B in reply to patsdeere, 11-22-2007 11:05:05
Shoot me an email and I will share a couple pictures of the fork and two bolts needed, these from an unstyled BN yoke. I don't know if the same is true for yours - but you can decide.
In verbal terms, I have a 3/8" dia bolt at the bottom of the fork tine on each side which retains the axle in place, and a smaller set screw above the axle on one side (right) which is turned into the bearing load nut so the adjustment remains as you set it up. And since this screw was so close to the axle nut, I cut the head off and installed a screwdriver slot in its end. And YES, for this screw, there are threads in the fork. (PatB)
patsdeere
11-22-2007 11:40:02
 Re: 46 B in reply to P Browning, 11-22-2007 11:28:00
That sounds exactly like what I have. I just thought about the threaded fork a few minutes ago. I will see if I can find a screw that works on it.
Thanks for the help.
Happy Turkey Day.
greenmech
11-21-2007 21:48:07
On the lights, you may need to clean the grounding surfaces where they mount. Try opening the load and idle needles more, else your carb may need cleaning. Ron Mn
