Bent PTO Shaft
Resting Relics
11-21-2007 06:11:55
Hey guys, I have a 42 "A" with a noticeable bent PTO shaft. This tractor was in the process of being restored when I got it. About all it did was roll around. The engine didn't run, brakes were frozen, no sheet metal, and the drawbar assembly was off the tractor. The guy I got it from pushed it around his yard with his loader and I think thats when he bent the shaft. With no drawbar to protect it from pushing from the back, I think he would lift the backend by accident and thats when the shaft got bent. My question is has anyone tried putting a pipe on the shaft to straighten it. I not looking for it to be perfect because I don't plan on using it but would like to get it close. Would I break the bearing housing or is this shaft relatively soft and will bend back easily. Thanks John
4020LP
11-21-2007 17:56:24
 Re: Bent PTO Shaft in reply to Resting Relics 1, 11-21-2007 06:11:55
Not that difficult to find and install a straight shaft. Even though you won't be using it, it will make the tractor more valuable.
Mike M
11-21-2007 06:58:45
I would try to find another shaft. But if I was to straighten it I would pull it out and use my hyd. press to do it. You might need to have it checked for cracks too.
