730 D pony mtr shot.
Grabatire
11-20-2007 22:57:20
I just aquired a 730 diesel that has a crapped out pony motor. I'm think'n of switching it to electric start. Any idea where to start looking for the parts or does someone make a kit.
I tried researching the classifieds but nothing showed up.
Grabatire
11-23-2007 20:16:50
 Re: 730 D pony mtr shot. in reply to Grabatire, 11-20-2007 22:57:20
Thanks everyone, I appreciate your candor and advice.
I opened the pony up and found a severly damaged crank and rod. Even if undersized brgs. are available, both the crank and the rod are beyond saving. I'm not in a rush so I think I will spend the winter looking for some used parts. If nothing shows up by spring it will get the electric start treatment.
gtx1967jewison
11-22-2007 20:31:34
just my 2 cents- the ponys are priceless timeless & 1/2 the reason to own a 2cyljd diesel. but to pertain to the question- either in 2 cylinder magazine or green magazine someone sells a kit for around 4 or 600 if i remember, & comes with everything (so they claim) needed including a lifetime warranty. good luck, hope u keep the pony- cant be beat in cold weather also.
BLinWMi
11-22-2007 17:19:10
There is a kit available on ebay on a regular basis, it sells for 525, and comes with the starter, bracket and plugs needed to fill the coolant line holes in the diesel. It doesn't come with a generator, but it is easy to get a 12 volt genny to put on it, or go with an alternator if you don't mind the looks of one. Alot cheaper repair than fixing a junk pony.
Grabatire
11-21-2007 20:54:06
I know the electric starter would lower the sale value to some extent but this tractor will be a keeper. At least until the estate sale (chuckle).
The former owner ran the pony out of oil. Apparently he fired it up on a cold morning and as was his custom, he intended to leave it turning the main engine and go tend to other chores until the pony ran out of gas. He would then refill the pony tank and because the main engine was now warmed up a bit from all the cranking, it would start. Unfortunately the pony seized up while in this prestart cranking phase. He initially assumed it had run out of gas so he filled it up and hit the starter. Nothing. He tried a few things like battery connections, another battery, etc then called me to have a look at it. Thats when I determined it was siezed. He offered it to me and I ended up with it.
Other than the pocket with the hole in it I don't have deep ones so I thought of the electric starter idea.
I have a complete machine shop at my disposal but was under the impression that an electric starter kit was available. Hence my initial post.
Thanks
buickanddeere
11-22-2007 00:37:20
 Re: 730 D pony mtr shot. in reply to Grabatire, 11-21-2007 20:54:06
The former owner must have went through some sets of ignition coils if the engine was let sit with the ignition on but not running. A full tank of gasoline is a lot of pre-heating and wear/tear on the ring/pinion. Even in sub zero temps around here. The diesel will start easy enough after two minutes of cranking. You might get lucky and the engine will run with a set of bearings,gaskets, sleeve seals, water pump seals and a set of new rods?
F-I-T
11-21-2007 09:12:00
GT:
As a guy who has gone through a few pony motors which had major problems, I can tell you that they are pricey if repaired correctly. While it is true that if you want to retain the purest state of the tractor as it pertains to resale/collector value, then repairing and making usable again the pony system is probably the best decision. Some folks are pony purists, and I tended to be, but I am beginning to see that an electric start conversion, done neat, could really help the functionality of an old diesel. I"m contemplating acquiring a pretty tired 70D which has a bad, bad, bad pony, and since my other tractor drivers never seem to want to learn how to use the pony system, an electric conversion on that one might be the best solution. I would keep everything that you remove in a nice sturdy box, bolts and all, as the next fella might want to put it back to original.
Now that"s enough pontificating, so to your question. There is no real kit that I know of, though I think an outfit, maybe it was Clyde Wilson, or Wilson Farms in Ohio offered a welded up bracket and a starter. Agriservices can help you out with a wiring harness. There was a thread just a few days back that discussed which modern starters could be used. You"ll have to change the fuel gauge as the 6 volt unit was different form the 12/24 unit. The sender is the same. And don"t forget the light bulbs. Then you"ll need an alternator or a 12 V generator. If I were to do it, I think I would look at a pair of big Optima gel cell batteries. They hold a charge well, give up a lot of CCA"s, and two in the pony sized battery box should fit just fine. Here in north Florida, I think it would start a 70 D just fine.
Frank
THE SMOOTHED DEERES
11-21-2007 08:09:45
You will lose tractor value if u switch it to electric start !
buickanddeere
11-21-2007 00:02:31
What is the starting engine doing and not doing? What is your budget in time and money to convert to electric? What is your access to tools & a shop?
John Hurron
11-21-2007 23:30:21
 Re: 730 D pony mtr shot. in reply to buickanddeere, 11-21-2007 00:02:31
buickanddeere
11-22-2007 00:30:45
 Re: 730 D pony mtr shot. in reply to John Hurron, 11-21-2007 23:30:21
Read the initial post again. Quote "a crapped out pony motor". Unquote.
John Hurron
11-22-2007 23:15:54
 Re: 730 D pony mtr shot. in reply to buickanddeere, 11-22-2007 00:30:45
Read on down and it says it is seized up
