60 Starter won't stay engaged
DJR
11-20-2007 19:30:33
I replaced a starter bendix gear in a 60 a few months ago because it was grinding. While it was out we put in brushes and a new switch. Now when the tractor is cold it disengages almost as soon as it starts to fire so it never starts. It starts so easy when it is warm that it is not much of a problem but when it is cold it never turns over long enough to start. Does anyone know if there is some adjustment to make it not kick out so soon? Any advice would be appreciated!
Dave
LarrySTN
11-21-2007 04:22:35
 Re: 60 Starter won't stay engaged in reply to DJR, 11-20-2007 19:30:33
You have a bad starter drive (Bendix) The starter drive has an over running clutch inside of it and the problems of early disengagement of a starter drive is usually caused by over running clutch failure. New ones don't always work the way they're supposed to. Intermitten weak firing of an engine should NOT disengage the starter drive.
RalphinWI
11-20-2007 22:40:15
Theory - Your tractor is wanting to start on the first stroke, but the mixture is too lean or ignition is off enough so it lacks the power to keep running. The flywheel is outrunning the Bendix and disengaging. I would do some minor adjusting on the carburator and ignition before doing anything else with the starter. If that doesn't work, try rolling the engine over a couple times before turning on the ignition and using the choke. Be prepared to clear the pigeons from the shed if it backfires. Basis: I used to be a regular user of the tow chain on our A, while my Dad could start it on the first try almost without fail. He would hit the starter and on what seemed about the third revolution, he would choke it for about 1/2 a revolution and he would be on his way. That was with a '47, an poor to average 6 volt battery and a well worn!! Bendix. Knowing the battery I always tried to start it on the first revolutions and usually failed. Let me know if it works.
Mike M
11-20-2007 19:33:25
I'd say you drive is slipping. You musta got a bad one.
