4010 trans
K D Wkp
11-19-2007 16:42:32
I am looking at a 4010 to buy but trans is stuck in reverse
Bob
11-19-2007 17:20:05
 Re: 4010 trans in reply to K D Wkp, 11-19-2007 16:42:32
Is the shift lever physically stuck in that position, or is it possible to move the lever to neutral, but the tranny remains in reverse?
If the lever is simply stuck, disconnect the rod down below, at the shift arm, and see what's stuck... up above, or down below.
If it's down below, and the tractor has sat outside a long time, it COULD be just the shifter shaft stuck in the case by rust.
Otherwise, if it's INTERNAL, it could be a broken shift fork or cam, or shift collars and sychronizers on the trannie's topshaft worn, broken, or out of place.
Also, if there's a possibility the tractor has been towed without being shifted into the "TOW" position, gear(s) and/or shift collars on the topshaft may have been welding in place due to overheating from lack of lube.
powertech84
11-19-2007 17:17:26
whats the question? syncro is probly bad
K D Wkp
11-19-2007 17:56:11
 Re: 4010 trans in reply to powertech84, 11-19-2007 17:17:26
the linkage moves but will not shift in the trans
