4020 motor - 7700 combine?
Reaver
11-19-2007 15:07:54
My father's 1967 JD4020 diesel blew up a few weeks ago. Metal in the oldpan and antifreeze in the oil...we are thinking it dropped a valve and who knows what else.
Anyway a neighbor has a JD7700 diesel combine that he says runs good and the motor would fit the 4020? Is that true?
I have always heard that a 4400 combine would fit a 4020 tractor? (and a 3300 combine would fit a 3020 tractor).
It has been a great tractor and we definitely want to fix it...just looking for the best route to go.
Appreciate your input.
Reaver
WTW
11-20-2007 07:32:33
 Re: 4020 motor - 7700 combine? in reply to Reaver, 11-19-2007 15:07:54
Reaver, If you want an early 77000/late model 4020 engine, I have one running and ready to install. This is the same engine as a 1972 model 4020 would have in it. It was the best 404 4020 engine of the three different ones used in the 4020 series. It will fit directly in your 1967 4020 without any modification. You will need to use your manifolds and oil pan as the combine engine parts are different. I have re-powered many of these tractor Gas and diesel and can give you any or all instruction to do so. If interested give me a call, come hear it run and take it home. Engine is out in shed high and dry. If you want bring me your tractor and I will put it in for you too. My cell phone is 319-389-6131. If your neighbors combine engine has the injection pump in the same location as your 4020 it will fit your tractor. If not it will require modification, not near as easy but can be done. Thanks, DW
5020s rock
11-20-2007 01:38:54
hi--sorry about the 4020. the other guy is right an early 7700 motor is ideal....good luck
finding one!! i have been looking since january.
i did buy a 6600 motor non/turbo and i am installing it now. also, you should check out the
"whole" situation of the current motor. FYI--
i do have a crankshaft if you need one,
std/std.....check the classifieds.
Tech 7
11-19-2007 20:04:43
just my 2 cents (Canadian eh?) but why not check out whats really wrong with the 4020? Have you owned it for all its life? If so whats the service history,has it had engine work done within the last 20 years how many hours on it etc. If by chance you could bring it back to good running condition with an in frame overhaul at least you know what you have when you are done..... .....Bob
4020LP
11-19-2007 15:34:02
The early 7700 combine engines will fit with little trouble, search the archives here, you'll find out what you need to know, the main thing is if the block is drilled for the hydraulic pump mounts. As for the others, the 4400 combine engines will NOT fit into a 4020 tractor, and the 3300 combine engines will NOT fit into a 3020. The 3300 combine engine will swap into a 2510/2520.
