Wanted: Used 4020 rear Fender Supports.
4x4dually
11-19-2007 13:43:55
Does anyone have a set of used ones for cheapo? New ones are way high! I'd like to move my fenders out over the tires instead of them being bolted onto my ROPS.
Thanks! I'd be much grateful for a bargain!
4x4dually
11-26-2007 05:52:33
 Re: Wanted: Used 4020 rear Fender Supports. in reply to 4x4dually, 11-19-2007 13:43:55
If anyone knows who "hfarm" is, let me know. I got a message on my regular email that said they had supports for sale but I can't reply. It says " the user doesn't exist."
Where ya at hfarm?????
4x4dually
11-21-2007 12:16:35
The ones are Ebay are more expensive than if I bought them new from the local JD store!!!! They must be fishin' for deep pockets .....
Maybe I miss understood you Gerald. I took it you had a set you'd sell. Maybe you meant you just had a set? I'd sure like to know. Thanks. JWB
Mike M
11-20-2007 10:17:54
Keep checking ebay.
4x4dually
11-20-2007 10:31:09
 Re: Wanted: Used 4020 rear Fender Supports. in reply to Mike M, 11-20-2007 10:17:54
One set out there for $90 for one bracket and one u-bolt. Heck, I can buy them new from John Deere for $87 plus $10 for the bolt and not pay shipping. Polk Equipment has a used set of two brackets and two u-bolts for $125 for all plus shipping. I thought if I could find someone that had them settin' around not using them they could at least get some money for them. I'm looking for a real bargain. Maybe Gerald will hook me up!
Mike M
11-20-2007 10:39:47
 Re: Wanted: Used 4020 rear Fender Supports. in reply to 4x4dually, 11-20-2007 10:31:09
Just keep checking as ebay has them all the time from just normal folks looking to sell some used ones. I saw some fenders pretty cheap new and used and brackets too just last week.
Gerald J.
11-19-2007 14:30:22
The fender supports that I took off when I mounted my ROPS probably won't fit outside the ROPS. I wanted 30" rows and the fender mounted ROPS limit the 18.4 tires to 64" centers.
I do have a set of fender supports, probably weigh 35 pounds each, sturdy steel castings.
Where are you located?
Gerald J.
4x4dually
11-20-2007 14:14:27
 Re: Wanted: Used 4020 rear Fender Supports. in reply to Gerald J., 11-19-2007 14:30:22
Gerald, any idea on price? I'd sure appreciate it!!!
Thanks, JWB
4x4dually
11-20-2007 06:45:25
I believe my tires to be at their widest setting, not sure what that is, but I can always move them there. I only do dirt work and move hay bales and mow pasture with mine. I don"t cultivate any land other than the wife"s garden so I"m not concerned with width. The wider is better for me. Right now, the inside edge of the tire is directly above the outside edge of the fender so they can move a long ways. I"m in Stillwater (actually Mulhall/Orlando) Oklahoma. What will ya take for them? You can send direct to [email protected] if you like. Thanks Gerald!
