JD 336 Haybaler
BigTex
11-19-2007 13:23:02
Can anyone give me info on this baler? How old? Can you get parts? Is it reliable or does it require a lot of upkeep? What should I expect to pay for one in fair condition? If it has been sitting unused for 4 years in an open field, will this be a problem?
DSK
11-19-2007 16:36:47
 Re: JD 336 Haybaler in reply to BigTex, 11-19-2007 13:23:02
I am still using the 336 my Dad bought new in 1973. It is without a doubt one of the best balers Deere ever built. Although I only bale about 1500 bales a year, it has seen countless thousands from the years we had a dairy herd and 50+ acres of alfalfa,(with no round baler or chopper, we square baled everything including 30 acres of oats straw). As for one that has been setting out in the elements that long, it will be worth considerably less than one that has been shedded, especially if they left hay in the balecase, which would cause it to be very rusty. It's hard to put a value on a machine without seeing it, but it sounds like this one is going to need some work. If you can do it yourself, great, but in this day of $75 an hour for a mechanic, you don't want to pay too much to start with.
Matt Weltz
11-19-2007 14:05:13
John Deere made them in mid to late '70's. Considered mid-capacity baler and one of the best ever made by Deere. I bought a good used on this past spring for $3500 which is a very good price here in Iowa for the condition of this baler. Baler that has been sitting out might be good. Hard to say - alot depends on location, maintenance before and after it was parked, and how much work you want to put in it to get it going again. Couldn't say whether or not I would buy it unless I had taken a real good look at the baler and had a long talk with the owner about it. Otherwise, its up to you...
