IT Shop Manual...NOT IMPRESSED. Options?
4x4dually
11-19-2007 11:18:47
I recently purchase the I&T Shop Manual and was not impressed. Having never split my 4020 before, I needed the assistance. It did give me step by step like "remove nut" "remove spring" remove this and that....but didn't tell me how to remove anything?
Is there any other manuals out there that give "step by step" instructions on where and what and how to remove/replace? Thanks for any help. I'm doing a clutch rebuild and have never done it. I have everthing apart and am waiting on parts. We'll see how it goes back together.
4x4dually
11-20-2007 14:13:02
 Re: IT Shop Manual...NOT IMPRESSED. Options? in reply to 4x4dually, 11-19-2007 11:18:47
Wow! This thread sure went into the weeds!! The IT is well written for its intended purpose, I just didn't know what its intended purpose was....to provide a general overview of repairs....not a "full-service" manual.
I hope no one takes offense to any of my posts, I wasn't slammin' the IT...not too much anyway. I prolly got at least $15 out of the $30 book. :)
Back to our regularly scheduled program....
buickanddeere
11-20-2007 10:20:07
 Re: A bit of hyperbole?? in reply to 4x4dually, 11-19-2007 11:18:47
JDemaris
As you noted and posted earlier quote " making jokes " unquote. Most of the jabs about IT manuals. that I make anyways. Is intended to be a bit of humour.
jd2830
11-20-2007 04:52:15
IT manuals stand for In Trouble
lonzo
11-19-2007 23:04:27
The manuals are alright most of the time and alot better that nothing but they really shine when the parts folks don't under stand what you want, i ask then to get a IT manual on the same tractor and turn to page so and so and look at what ever and then i KNOW what they are looking at. Really helps,
jdemaris
11-19-2007 17:19:50
I guess I've got the dissenting opinion. I like I&T manuals - they are brief and to the point without wasting paper on fluff and superfluous stuff I already know. They used to cost $3 apiece - and weren't expected to have all the data an OEM factory manual would have.
I worked at three Deere dealerships - 1967-1991, and each shop had a complete set of the I&Ts - for just about every tractor made. We liked to have them for all the off-brands we had to fix - but we also tended to use them for the Deere tractors also - even though we had all the factory tech-manuals. Yes, there were times we had to refer either to a Deere tractor manual - or a Deere specific manual. Someone mentioned the IH Blue Ribbon books. Deere had an equivalent, and had/has service manuals for electrical systems, fuel injection systems, hydraulics, etc. Again - I&T was never intended or pretended to have all the data and diagrams a factory manual has - but does usually have all you need to fix a tractor if you already have mechanical experience.
In some cases, the I&T has more hard facts than Deere factory manuals. One excellent book for any shop is the I&T Standard Units book. I don't know anywhere else that has all those generator, starter, magneto, carburetor, and clutch specs for so many different tractors all under one cover. In reference to your complaint about your I& T book not telling you how to split your 4020? Admittedly, I hadn't looked at a book in years for that info since I already know how - but . . . I'm looking now at three I&T books - all written for 4020s. JD20, JD23, and JD29. They all have the same section titled "Tractor Split 3000-4000 paragraph 82" and it looks thorough enough to me.
Bob
11-19-2007 18:21:21
 Re: IT Shop Manual...NOT IMPRESSED. Options? in reply to jdemaris, 11-19-2007 17:19:50
Yep... An I&T manual is REAL impressive when there's a weird hydraulic problem, and you need hydraulic flow charts!
Like Buick says, "about as useful aas a paperweight"!
wilamayb
11-19-2007 19:03:42
 Re: IT Shop Manual...NOT IMPRESSED. Options? in reply to Bob, 11-19-2007 18:21:21
An I&T is better than a poke in the eye for tractors that never had a Tech manual written for them.
An I&T is the only technical information we have ever owned for any of my letter series two cylinders. With a JD parts catalog and an I&T I've always manged to make them run pretty well.
All that said I would agree that there is no replacement for a Deere manual for the later tractors. There are just somethings that only the creating engineer knew about the tractor. Deere spent hours and hours creating the parts to make up the tractor. If they dont know about it no one else does either.
jdemaris
11-19-2007 18:40:11
Sorry I don't share your disaffection with the I&T books. I find them very useful for the majority of (but not all) tractor repairs. I've fixed hundreds off odd-ball tractors over the years, using mostly just those books. So did other guys in our shop. We did just fine with them. So . . . if you and Mr. Buick/Deere find a "paperweight" more useful and easier to read - maybe you ought to get it copyrighted.
buickanddeere
11-20-2007 01:10:06
 Re: IT Shop Manual...NOT IMPRESSED. Options? in reply to jdemaris, 11-19-2007 18:40:11
The IT manual has plenty of other uses too. It can be placed on the bench to prop up the JD manual and protect it from getting greasy. The IT manual can be wrapped around parts to protect them from getting marred in the vice. And the IT manual can hold open doors or windows. Of course the IT makes a fair coffee coaster to protect the deck and other paperwork.
jdemaris
11-20-2007 05:50:34
 A bit of hyperbole?? in reply to buickanddeere, 11-20-2007 01:10:06
Well . . . maybe not everyone wants - or needs - to spend hundreds of dollars on factory shop manuals. Especially if they work on many different brands. You can sidestep the issue of their worth by making jokes - but the reality is this. Somebody with tools and mechancial skills can get a lot of use out of an I&T manual. I worked in three shops where they were used most of the time - and most of the time - they gave us all the info we needed. In the 50s and 70s, they only cost $2.50 to $3.00 each. Now - for somebody that is not a mechanic and needs every possible move explained to them - then yeah, a factory manual can be much better (but not all of them). And, for something uncommon and/or proprietary - e.g. a Deere selectrve control valve, Power Shift transmission, closed-center variable displacement piston hydraulic pump system, etc. , &c. - well yeah again - you might need a OEM factory manual - and I stress the word "might." My last boss at a Deere dealership kept a room for all the expensive Deere manuals - and in the shop - we had stacks of I&Ts. We weren't supposed to get the Deere books greasy - and we all wound up using the I&Ts most of the time. We did just fine. In fact, according to the Deere boys in Syracuse - our Deere dealership in Oneonta, New York, had one of the best repair records in the Northeast at the time. Deere even gave me some stupid award for repair excellence - called the "Golden Beltbuckle", "Golden Wrench" or something like that. One note though - I haven't bought, nor have I looked at any new I&T manuals in years. The last new one I bought - JD-29 (3020-4020-5020) still has the Central Tractor price tag on it of $3.00. My oldest version of the same - JD-20 has a price tag on it of $2.25. I know they no longer sell for $3 - but as far as their content now - I have no idea if they've changed, or not.
P Browning
11-20-2007 06:08:37
 Re: A bit of hyperbole?? in reply to jdemaris, 11-20-2007 05:50:34
jdemaris -- I think you have tried over & over to make your point. So now comes the time for you to give it up already.
I&T manuals filled a vast void in the Deere documention world, no doubt -- but Deere learned somewhere along the way (so it would appear) that demand WAS there for Deere service manuals. Were this not the case, I&T manuals would be ALL we would have to choose from.
I will grant you -- for the mechanic who makes a living and needs only an occasional look into ANY shop manual, I&T fills the bill. But for a beginner -- the service manual is expected to fill a huge void left by the parts catalog and operator's manual, and he will be hungry for far more information than is found in the I&T manuals.
The truth be known, the ideal service manual would be a restoration guide! And there are a few of those out there, but none that are really comprehensive/complete! Now -- there's a void YOU can fill -- given your many years on the job. Experienced writers are few and far between. I have to warn you though, folks are looking for more that a breakout drawing and a few sentences telling them how to take something apart followed by the one more sentence that says to re-assemble, reverse the steps of dis-assembly! (PatB)
jdemaris
11-20-2007 06:59:50
 Re: A bit of hyperbole?? in reply to P Browning, 11-20-2007 06:08:37
Have you been given authority to order me to cease with my point? If so, show me your badge.
No matter how well a book is written, and regardless of style and/or content, it's not going to be the "perfect" book for all people and situations. People differ too much - with their skill level, tools available, and what exactly they are looking to do.
I guess we're lucky to have many choices. I buy OEM manuals for all my cars and trucks because the I&T equivalents - Chiltons and Haynes - are much more useless to me - than I&Ts are for tractor work. I also buy OEM manuals for all tractors I own - when possible and when priced reasonably.
I can fix almost any problem on any tractor with an I&T manual. I can't do the same with a car or truck using a Chiltons or Haynes.
My point was, still is, and will remain to be - there's lots of useful information in the I&T books. Are they comprehensive? No. It seems though, that they dropped one their best publications - Standard Units.
P Browning
11-20-2007 07:47:46
 Re: A bit of hyperbole?? in reply to jdemaris, 11-20-2007 06:59:50
This is very interesting -- if you were to read your post over a time or two - you will pick up the notion that one who is well versed in cars & trucks may come to rely heavily on Chilton's but seek Manufacturer's service manual for their tractors. I know of a man or two falling into this category.
So you see, it is a matter of background. Some of us like those nice additives in a service manual and some of us do not need them. I believe it is as simple as that.
What is often overlooked here is that at any given point in time, a huge number of folks messing around with antique tractors are not well versed in the hobby. Actually, for each and every one of them, there was one of a few beginning points. Many had one or more on the farm during their younger years, and some were kind of lead into the hobby by a friend or as a result of attending some event featuring tractors. And then there is a definite minority in terms of numbers of those who were tractor technicians during their work life. And you do not have to think long to realize the needs for documentation for each groups will surely be different.
As for giving you an order -- you take it to the bank -- it wasn't my intention. And if you took it that way, you have my sincere apology. I don't mean to ruffle feathers but rather -- communicate. You will have to admit -- many commenters do not think much of the I&T series as shop service manuals, and I generally agree. I wish for you a Great Day and a Happy Thanksgiving. (PatB)
jdemaris
11-20-2007 10:16:45
 Re: A bit of hyperbole?? in reply to P Browning, 11-20-2007 07:47:46
Well - without rehashing the aforementioned - the I&T books certainly are more useful than a paperweight. To discredit them to that level is rediculous. There are many people at certain skill levels that get along fine with them. In some circumstances, they have details you cannot find in an OEM Deere manual - especially with late 50s, early 60s tractors.
One thing I particulary like (or liked) about them - is their common phrase "assembly is self-evident", which . . . to paraphrase . . . connontes - "if you can't figure this one out yourself, you shouldn't be allowed to own a wrench." They don't waste a lot of time or paper explaining simple, generic functions.
My needs are bit different for tractor repair data since I've been doing it my entire life. I still experience the feeling though - of being totally new and clueless to something technical. It happened when home computers first came out. Also when satellite TV was in its beginning stage. So, I still get into things that require some sort of comprehensive book that attempts to lead me every step of the way. I say "attempts", since in my experience, it rarely works. The real learning - for me - takes place when I actually dig into something, and perhaps screw it up a few times. I'm pretty good at making bad mistakes only once, and learning well from them. It's worked with tractors, cars, and wives.
Mike M
11-20-2007 10:36:10
 Re: A bit of hyperbole?? in reply to jdemaris, 11-20-2007 10:16:45
What everone seems to overlook ( probabaly from the low price ) is reading the first page of an I&T manual that I think cleary states these manuals are for the professional .
And how can they go around knocking the content in them as alot of it AND the pictures are copied right out of the factory manuals ?
I sure don't understand this hate toward them ?
If they want to hate something maybe thay should direct this anger toward a company that has long ago since paid off any costs makeing up the old manuals and in this day and age of cheap copying they are still wanting way overinflated prices for their manuals and won't let anyone else set them up for free view on a website. There is a fellow doing just this with other brands.
jdemaris
11-20-2007 11:45:13
 Well . . how dare IT make such a book in reply to Mike M, 11-20-2007 10:36:10
Watch it - you're going to get somebody ticked off. How dare I&T sell a manual geared for somebody who is already experienced as a mechanic and needs some hard facts without the added fluff.
The older manuals from the 50s - make it very clear with the following in the intro:
"Contained in it are the necessary specifications and the brief but terse procedural data needed by a mechanic . . . "
Note the words "brief" and "mechanic."
Also explained is . . . data is NOT included for . . . "carburetors, clutches, ignition units, generators, regulators, and starting motors."
All that is covered in a separate I&T book - that of "Standard Units." I've got a stack of them - they are a fantastic refernce source.
I&T also made some excellent "service manual and pricing guide" books. For example, I have one printed 1960, priced at $4.95 that covers Deere MC, 40C, 420C, 430C, 440IC, and 440ID. It gives repair and flat-rate pricing information. It's 144 pages and has some infomation you'd have a hard time finding these days. But - maybe the hourly shop rates are a little outdated?? It shows a range - for shop labor charges - from $2.50 and hour - up to $7.50 per hour.
It does seem though, that as time goes on, I&T has put less of the disclaimer in the intro, raised the prices way up, and perhaps are attempting to cater to a different market. I haven't bought a new one in years - but have noticed the price tags.
F-I-T
11-20-2007 11:21:46
 Re: A bit of hyperbole?? in reply to Mike M, 11-20-2007 10:36:10
I like them. I believe that they are akin to the "Cliff Notes" of tractor repair. If you read a real Shakespeare play one time and just need a refresher at a later time, Cliff Notes will do just fine, but you should have read it for real...at least once. Same goes for a Schaum's notes for Chemistry. It will refresh the points you should have learned in the class room. I agree that if you still have to say out loud "Righty-tighty/Lefty-Loosey", then you need the best manual you can buy. On the models I own and intend to keep for a long time, or go into really deep, I try to get the Deere book. I will say that the I&T manual really does a fairly good job on items such as the power steering system, but you have to peruse ("to read carefully") until you understand what they are trying to get across.
I certainly would not turn down a Deere manual if I have that available, but I won't detract from an I&T manual if you are experienced enough to understand when disassembly is evident, common mechanical procedures, and you have a history of having successfully disassembled and reassembled countless mechanisms. A lot of people buy a $150 manual and don't have a single decent micrometer. Choices, even bad ones, are made every day.
Bob
11-19-2007 18:21:16
Bob
11-19-2007 18:21:07
Bob
11-19-2007 18:22:28
 Re: IT Shop Manual...NOT IMPRESSED. Options? in reply to Bob, 11-19-2007 18:21:07
Yep, I'm SO impressed I stutter!
(SORRY about the mutltiple posts above!)
Gerald J.
11-19-2007 14:27:32
Be sure you get the correct 4020 shop manual and then the matching parts catalog. The side console tractor documents are not the same as the early 4020 books.
Gerald J.
Jason Z in MO
11-19-2007 15:07:19
 Re: IT Shop Manual...NOT IMPRESSED. Options? in reply to Gerald J., 11-19-2007 14:27:32
If you want, you can save the cost of the parts book. The 4020 parts manuals are on line at JDPARTS.
If you register and provide your dealer name you can check the price and if your dealer has it in inventory! Your basically have access to some of the same systems the dealer uses. Bet you can't do that with IH :)
Just kidding, I have an Farmall but had to poke back about the manual comment.
4x4dually
11-19-2007 13:33:01
Thanks! I have a salesman buddy at a JD store. I'll have to see what his "employee price" is on one! Now I've wasted $30 on this I&T, but it did help me get it apart in the right order. I'm sure I fiddled and farted around several hours more than it should have taken but I sure learned alot.
Jason Z in MO
11-19-2007 12:46:08
The Deere service manuals are VERY good and worth the money. I have referenced the manual for my 4020 countless times.
I have an IT manual for my 520 and found it has far less detail. Not only does it explain how to fix a problem it explains the operation and function. It's much easier to diagnose a problem if you know how it's supposed to work.
I will say if you buy from Deere it will be a copy and some photographs will be less than perfect. I think the original manuals had a few color diagrams; hydraulic oil flow, transmission, etc. The copy from Deere won't have this.
Hope this helps.
RobMD
11-19-2007 11:58:58
too bad international couldn't make a manual for deere, because international made the best
RossIL
11-19-2007 11:40:14
I have the old I&T manual for my tractor, I'm not crazy about it either. I imagine the Deere factory manuals are like the Blue Ribbon books for IH. They cost a lot but you get a lot in return.
Ross
4020LP
11-19-2007 11:30:46
I'm hesitant to suggest this, since it seems nothing can be said here without somebody being offended. However,there's always the Deere Technical Manual, available at 800-522-7448. Not cheap,but has step-by-step instructions far beyond I&T. Look around on flea-bay, sometimes they can be found there, too. Worth the $$ no matter which way you go.
Bob
11-19-2007 11:28:51
The DEERE factory manuals are BY FAR the best.
1-800-522-7448
