4020 Value ?
Dwain in Rowenn
11-19-2007 10:38:16
I found a 71' model 4020 diesel narrow front that is a powershift. The guy that owns it now bought it new, but he never kept inside. The clutch packs were rebuilt several years ago, but the engine has developed a knock. Just a ballpark guess, what would you think it would be worth? I'm guessing $2,000-$3,000, but I could be wrong.
5020s rock
11-20-2007 01:48:39
 Re: 4020 Value ? in reply to Dwain in Rowenna, 11-19-2007 10:38:16
hi--dude, you need a wake up call!!! if thats
the price buy it!!!!! if not give me the number!!
EVERYBODY LOVES A 4020....i called on one 800 miles away....knocking,pumping oil and smoke out the blo-by and he said $4,000, i hung up the phone. its was a 1965.
Ferd
11-19-2007 17:20:03
Watched a dealer buy three 4020 powershifts (late models) with canopies at a farm auction this spring and had to ship them 1500 miles to re-sell - he paid about $13,000 each.
wilamayb
11-19-2007 15:37:17
The 71 and 72 model powershifts seem to bring the most preimum price of all 4020's. If a run of the mill early model 4020 is bringing $6500 then a junky 71 powershift ought to do the same.
4x4dually
11-19-2007 11:13:41
Holy Cow? $2000-$3000? DO IT! 4020's 'round here will bring $6K if they are pices of crap! I've got my '68 diesel split right now for clutch repair. It is in good shape, runs great, has 720 loader with joystick controls and I paid $14 three years ago. I needed one bad, but even the junkers I looked at without loaders were $7K. They were all row crop standards with wide/adjustable front ends. Good luck.
Mike M
11-19-2007 10:55:31
If you can get it for that price range by all means DO IT !!!
Buckeye Oliver collector
11-19-2007 20:45:31
 Re: 4020 Value ? in reply to Mike M, 11-19-2007 10:55:31
Pobably the third most overrated tractor ever produced (8N Ford at #2 and Farmall M at #1). I'd rather have two good Oliver 1850s or IH 806s than one good 4020.
wilamayb
11-20-2007 07:11:02
 Re: 4020 Value ? in reply to Buckeye Oliver collector, 11-19-2007 20:45:31
The only one I can agree on would be the N series Fords. I never really found anything that the Ford excelled. The lift was very slow, the motor was weak and there were not enough working gears. It was too slow or too fast. I've spent lots of seat hours on all three of the mentioned tractors. I never thought the M or 4020 were over-rated. They were premium tractors for the time. I'll have to admit I would have had a hard time choosing a G JD over an M at the time. They always did what they were asked although maybe the M was a little thirsty.
I've always liked the olivers with the GM diesels, however it seemed to me that Oliver had a diesel engine problem. The remainder of the tractor is heavy and built well. If I had to swap my late 4020 for any tractor it would be for an 1850 Oliver with a GM diesel.
Mike M
11-20-2007 10:41:43
 Re: 4020 Value ? in reply to wilamayb, 11-20-2007 07:11:02
Those Fords excell at an abundance of reasonable priced parts you can get for them.
wilamayb
11-20-2007 11:26:31
 Re: 4020 Value ? in reply to Mike M, 11-20-2007 10:41:43
That is true. If you need it for an N ford there is at least five different groups making repro parts and they are cheap.
Maybe I just talked myself into an N Ford. HA HA!
How bout you Mike? Bob has one now. Maybe we should all get one?
Mike M
11-20-2007 11:37:24
 Re: 4020 Value ? in reply to wilamayb, 11-20-2007 11:26:31
I had one once and worked on several for others. I'd rather use my late B that I used to have to go unstick the neighbors Ford from the bottom ground. Those 38" tires give you more underclearance.
Mike M
11-20-2007 06:38:13
To each his own. My buddies back in my school days were die hard Oliver fans. Always lots of good hearted kidding going both ways. Well now the years have long past and it seems I have the last laugh as they now have several John Deere's and it all started when somehow they ended up getting 1 4020.
