70D water in oil
Scott Batts
11-18-2007 08:00:35
Hey guys, kind of new to the two cylinder diesels. Problem is I am getting water into the oil on the big engine. I didn't know if there was a weak point on these or not? check head gasket first or possibly somewhere on the pony getting through. Just wondered if there was a place to check first.
Thanks
Scott Batts
Blksmok
11-19-2007 07:16:46
 Re: 70D water in oil in reply to Scott Batts, 11-18-2007 08:00:35
Scott...first place to look is under the injection pump on the belt pulley side of the tractor. If the tractor was had water in it and froze, that's where it will crack. Also, look at the lower water pipe casting that is bolted to the cylinder head. If that shows signs of repair, the engine had water freeze in it. If those two items are ok, then expect a bad head gasket, or if you have the old style head, injector tube seals. I would not run it very much if you have water in the oil and/or water getting into the cylinders upon setting. Bad things can happen.
buickanddeere
11-18-2007 10:31:11
Which cylinder head is on the diesel? Late in 70D production the new head for the 720 was factory installed on 70D's. The 1st series tended to crack & leak. Then again it could just be old over torqued head studs, warped block/head, torquing without a torque wrench etc.
RobMD
11-18-2007 08:42:22
I'm quite sure FIT on this board mentioned at one point about water from the pony jackets dropping in the crankcase?? I've never had it happen but I sure hope it didn't happen to you- hopefully a blown head gasket.
ONE WAY TO CHECK- with the engine running, do you see WHITE smoke coming out of the stack? even if it's just a little? If so, it is your head gasket. IF NOT, then the pony is dumping it's water from somewhere, but I can't remember?
F-I-T
11-18-2007 11:02:54
 Re: 70D water in oil in reply to RobMD, 11-18-2007 08:42:22
I don't think that was me. The only way I know of to get pony water into the oil of the diesel is to drain it into the diesel crankcase after it has leaked past the pony water pump seals. You CAN have a bad donut gasket between the pony and the diesel crankcase top surface, and rainwater can collect there and run into the diesel crankcase from there, so if the water is not coolant colored, you might have a simple fix.
There are a couple ways to get water into the diesel oil. One is coolant from a bad head gasket, and the other is a cracked casting.
To find out the where and why and how and what, I would drain the engine oil, and put a clean bucket under it after the oil slows to a drip. Then I would pressurize the radiator and watch for dripping coolant from the oil drain. You should soon be able to ee coolant drip out and that means it is coming from the head gasket or a cracked head, or a cracked block. They did have a nasty habit of cracking the block under the fuel rail under the top cover of the block. You might look under there while the pressure is up to look for water/coolant.
Frank
