Question: JD M Clutch
Peat
11-18-2007 07:25:54
My JD M makes an vibrating/ growl sometimes when I put in the clutch and have no more clutch adjustment, at times when I put in the clutch at a higher rpm it does not disengage.
Looking at slpitting the tractor and replacing clutch and throw our bearing, is this a job a weekend shade tree mechanic can do? Or should I seek professional help? OK no wise cracks here...
Thanks guys.....
Gary North of Spokane
11-20-2007 20:26:47
 Re: Question: JD M Clutch in reply to Peat, 11-18-2007 07:25:54
You mentioned replacing the clutch and throwout bearing. We did that and my M continued with the same symptoms that you described. Split it again and checked everything out. Seemed ok, but when we started it up, NO JOY. Same symptoms. We replaced the pilot bearing in the flywheel (actually a bushing) and it works perfectly now. Suggest you clean up the end of the shaft that goes into the pilot bearing with emery paper or something and pack the area behind the pilot bearing/bushing with grease before assembly. Learned this the hard way; all that was really wrong was the bearing/bushing to begin with!
Resting Relics 1
11-19-2007 06:03:02
Peat, The hydraulic lines are the biggest pain. Tough to get them out of the way enough, but with a little pesistance you can do it. I've done them by holding the front stationary on a bottle jack and blocking the front axle so it cant't pivot, then roll the back half on a floor jack. Be sure to put on jack stands when you have it rolled back and put the front half on a good saw horse or blocks. Your going to need some kind of clutch plate aligning tool so you will be able to get it lined up correctly to put back together. Good luck and be carefull.
RobMD
11-18-2007 08:46:21
a shade tree mechanic can do this, but you really got to build a rollaway system to roll away the rear of the tractor from the front. I built mine out of an old steel welding cart and 2x4's.
You can do it. You will need a new throw out bearing and whole clutch. Does the clutch ever jump or vibrate? you might want to pull the flywheel and have it turned down flat.
