JD 40 Standard
Twincreeks
11-18-2007 06:05:34
I have a JD 40 S and when I pull the throttle all the way open the tractor reves up, then goes back to half throttle. It has two springs on the throttle rod. Could they be wore out.
Thanks Mike
Dave H
11-18-2007 17:43:24
 Re: JD 40 Standard in reply to Twincreeks, 11-18-2007 06:05:34
It is the friction disks just like stated before. You will probably have a bucket of yucks changing those out.
I think the most important thing is holding my tongue just right.
bill mart
11-18-2007 07:14:39
does the throttle lever stay in the same place or does it go back to a lower setting?
Twincreeks
11-18-2007 09:19:33
 Re: JD 40 Standard in reply to bill mart, 11-18-2007 07:14:39
Goes back to a lower setting
RobMD
11-18-2007 09:22:13
 Re: JD 40 Standard in reply to Twincreeks, 11-18-2007 09:19:33
your friction disks are wore out. These disks hold the throttle in a fixed position at the lever.
steveormary
11-18-2007 06:48:20
Could be the governor. I have operated some old er tractors that you can pull the throttle to wide open and the engine wont rev up much untill you put a load on it.
steveormary
