Changing wheels isn't all that hard. I did that to my 4020 last year for better spraying. Went to 12.4-42 for better crop sideways clearance. Gives me the same ground clearance as the original 18.4-34. Could be that going to the wheatland tires fit better with the wheatland fenders. I had to move the fenders on my 4020 when I put the ROPS on it, because the fenders now mount to the ROPS. It was clumsy, but I hitched a pulley to a rafter and lifted them by myself. I used a cherry picker to help move those tires and rims off and on the tractor. I had to make custom adapters to get those 42" rims mounted to the 34" centers. Seems like the fixed front axle and the lack of three point are what distinguish the wheatland tractor. Again front axles were made easy to change so all the 3010 through 4020 front ends interchange using the same steering motor, some mount on the steering motor, some have their own mount and are turned by the steering motor. 8 bolts as a maximum after you hold up the front of the tractor. You don't have to move the steering motor, just bolt the right parts to it. Not a few factor front ends broke and were replaced with sturdier front ends from later and larger or aftermarket (generaly Schwartz) suppliers. Adding three point to a true wheatland tractor is a lot of work, maybe not impossible but nearly impractical because of all the rock shaft parts as well as the draft control feedback shaft through the bottom of the rear axle housing and the hydraulic control valve. I still think its a standard or row crop tractor with wheatland tires and fenders. That would be the easiest way to achieve that combination. With parts in hand, maybe a day's work for one man. Before I bought my 4020, I looked at 3010 through 4020 and a couple of the 30x0 I found here in central Iowa hadn't used the three point in so long that the control cable from the dash was rusted fast and I couldn't move the three point. Apparantly used only on pulled and PTO equipmnt, probably mowers and augers. A couple years ago my 4020 three point control cable did that even though I do use its three point regularly. This propane 3010 is a tractor that if you can fuel it, it will do a lot of work for you, and if you don't want to put propane in it, its a collectable because there weren't propane tractors many made in any form. Gerald J.
