51 A weak spark!
Badger Bob
11-17-2007 15:59:14
Is there any way to put electronic ignition on this old delco distribitor. thanks Bob
Badger Bob
11-21-2007 16:56:58
 Re: 51 A weak spark! in reply to Badger Bob, 11-17-2007 15:59:14
thanks guys ill give it a try. thanks Bob
John T
11-17-2007 19:52:27
Fer sure, Pertronix among others makes easy to install electronic switches to replace the points n condensor in those Delco Distributors. I highly recommend to get the most bang for the buck that switch has to offer that you match it up with a high energy high voltage coil and run a wider spark plug gap for a wider hotter spark. Be sure n get a switch to match the battery polarity remember.
John T
Andy Motteberg
11-17-2007 16:10:49
Yes, you can put one in. I think YT sells new kits.
