F.I.T. Just Pondering....!!
wilamayb
11-17-2007 12:36:00
Frank,
I have recently tossed around the idea of some way to evenly load a tractor after an engine rebuilt. I've gone through them all.. Baker fan, big water pump, hydraulic pump, dyno, etc. etc...
I was reading some info in the archives when you and some others were also talking about building an anjustable load device for the belt pulley. Did you ever make anything?
I've got all types of implements, but it is hard to get a good even load at say 60%. I bid on a M&W dyno a few months ago. It was in NY state and brought big $$$$$. I was not the proud new owner, athough maybe I should have been?
I've even tossed around making a break-in device for my pony engine. I have every intention of having the rings seated before it is even remounted on my 720. I've not gotten that one figured out either. LOL
Resting Relics 1
11-19-2007 06:31:19
 Re: F.I.T. Just Pondering....!! in reply to wilamayb, 11-17-2007 12:36:00
Hey Wilamaybe, I use a pto driven 30KW generator that we use around the house and shop when the power goes off. Depending on the size of the tractor that I'm working with determines how many "extra" things I'll turn on such as electric stove clothes dryer etc. Works well. John
buickanddeere
11-19-2007 08:25:12
 Re: F.I.T. Just Pondering....!! milkhouse heaters in reply to Resting Relics 1, 11-19-2007 06:31:19
I was just at Princess Auto and was flabbergasted at how cheap 4800W forced air milkhouse heaters were selling for new. On the to do list is to set up a splitter box with a plug directly into the generator. And a row of 30A plugs for about 8 4800W heaters and a couple of 15A for a pair of 1500W heaters. A current transformer hard wired into a ammeter, a cheapo digital voltmeter, about 5 amps of P.F. correction capacitor. A 2.99 calculator and presto, a dyno that doesn't leak oil or require a water supply.
F-I-T
11-19-2007 14:13:28
 Re: F.I.T. Just Pondering....!! milkhouse heaters in reply to buickanddeere, 11-19-2007 08:25:12
That's all well and good, but wouldn't you really want a truly variable resistive load so that you could measure the tractor torque/horpsepower? Seems you have an incremental load, but not variable. I know you can get close, in steps, but you'll never know exactly what you have for comparison purposes.
Now, if you place the generator on a pivot, you could measure the force at X-feet moment that the generator is receiving convert that particular load. That to me , if you do use a generator as the load, is still looking like something that would not cost too much to rig and the data would be pretty valuable. Set the genny on a longitudinal axis pivot, counter-weight it to compensate for any friction in the pivot, then let the genny swing down (or pull up)a moment arm against a good bathroom scale to see what force it takes to spin it.
Is there a way to safely alter the field current of the generator (alternator) to get a variable power output? That way if you shifted multiples of 4.8 KW strip (6.4343 hp ea), maybe you could "trim" down the genny field current to get the electrical to sit right at the 540 power output of the engine. I'm a bit out of my element here, so understand my ignorance. I just wish I had one of those old 60 KW industrial induction heaters that we pitched in the trash at the shop years back. Now that would have been a nice dummy load. How much wattage does a good-sized electric water element draw?
BTW, if you buy a long enough extension cord you won't need a petrol burning tractor that leaks oil and drips water either! :)
buickanddeere
11-21-2007 19:41:34
 Re: F.I.T. Just Pondering....!! milkhouse heaters in reply to F-I-T, 11-19-2007 14:13:28
Controlling field current should not be a problem. Some generators even have a trim pot on the control board to set voltages. Using a generator set to pivot on it's center of gravity and reading lbs X ft/5252 =HP is an excellent idea.
Dairy farmer in WI
11-17-2007 18:01:22
one way that i broke in my re-biult farmall M was to run the blower for mixed silage ( corn / hay mix) but i tried to run strait hay throug but that stuff blows way too hard fer that tractor!. then i hooked it on a 10 ft disk after i chopped corn. now i got it on the 12 ft digger. pulls those just fine but work it real hard on hills
just my 2 cents
DF in WI
Mike M
11-17-2007 15:31:31
I have ran tractors on a pto generator before and used an electric furnace to load it.
I have preran pony motors before too. I didn't load them just warmed them up adjusted them and checked for leaks and then retorqued the cyl. heads before installing them. I c-clamped it to a bench and ran water into them.
F-I-T
11-17-2007 15:28:29
First, on the pony engine, IMHO, the best load you can present to that for break-in, would be to mount it, warm it up, engage and let it crank the de-compressed diesel through a tank or two of gasoline, then re-fuel, re-start, and have it crank the diesel on compression through another tank or two. You might have to actually eventually run the diesel to mix the coolant well as the pony doesn't move the coolant as well as the main engine. The biggest reason that keeps ponies from breaking in completely is too many cold starts and short runs, but mostly not honing the cylinder liners into the proper corss-hatch pattern. You need a fairly rough microfinish so that those cast rings grab and wring their pattern in in a short period of time.
On the load device for tractors, I drew one up, but I found an M&W 400A dyno in the mean time, so I out that on the back burner. The device that I planned was a Prony Brake, which next to an eddy current load, is the most accurate device you can use for loading and test measurement purposes. The old Nebraska lab tested using a Prony Brake. Today they use an eddy current dyno.
I had planned on taking an old transmission driven pto, inline engine type tractor chassis, say like a VAC/SC/DC Case or an IHC "M" to start with, and keep just the transmission/rearend/axle assembly. Then I planned to fabricate large flat "rim" to one wheel, and a calculated moment arm to the other axle. Then I was going to drive the pto (backwards) from the test tractor. By driving the pto, I could use the transmission to shift the rear axels into three different gear ratios to accomodate small, medium, and large tractors. Under the moment arm would sit a scale. A set of adjustable wooden brake pads (cheap to replace) could be slowly tightened down against the flat rim to provide the friction load, along with a misting of cooling water to keep things at a "normal" temperature and to keep the pads from overheating. Now you tighten down the brake until your test engine is running at its rated pto speed (535, 540, etc.), WOT, and since the rearend differential would try to resist the load on the brake side, the force would go to the other, moment arm side. When you read this downward force on the scale, after accounting for the length of the moment arm and the shaft speeds, you could accurately calculate the foot-pounts/torque to a fraction of a horsepower, and I think you would have repeatable results with this jig. I have most of the stuff around here to do just that, but no time right now. I am also thinking of building a mini-version out of a small car/truck rearend/tranny to try with small air-cooled engines, like 15-20 hp lawn mower types as a proof-of-concept. You would also have to caluclate the parasitic load of the mechanical conglomeration so that you knew what you had to add to the output result, but I think once you correct for that, your results should be darn near lab grade. I know it would be more stable/repeatable than my hydrostatic dyno. If you don't need to know the numbers, and just want to create a load device, just don't use a scale and let the moment arm rest on the ground. Use a shear pin for a safe guard or maybe an old rotaty mower or combine slipclutch. A few things to work through, but that's my thinking.
Frank
wilamayb
11-17-2007 16:51:00
 Re: F.I.T. Just Pondering....!! in reply to F-I-T, 11-17-2007 15:28:29
I like the idea of using the rear of another tractor to just hook PTO to PTO. For some reason that never really crossed my mind? I think the M Farmall might be the easiest to obtain around home. It seems as if there are several sitting in the junk pile.
I really have no desire to using the creation as a measuring device. I mostly want a device to control load in a stationary fashion for engine break-in, although it wouldnt hurt my others to have a good mid-winter warm-up.
I can see it all except for one "how to do". How were you thinking about making the rim that would rub against the wood? I dont think it would be a problem except that it is going to have to be pretty close to perfectly round. It would also have to be something fairly thick if we planned on running it for hours on end.
How are we thinking it would last with my 720D on the working end of the shaft?
I hope to have nearly a month at home during Jan. who knows what I may come up with while I'm there. If it's good and I'm not ashamed I may shoot a picture.
F-I-T
11-17-2007 18:14:14
 Re: F.I.T. Just Pondering....!! in reply to wilamayb, 11-17-2007 16:51:00
***How were you thinking about making the rim that would rub against the wood?***
I pictured a disk in the vertical, bolted to the face of the center wheel hub star casting, maybe slices of 3/8", or even 1/2" steel if you could find it. If you made a caliper using several wood blocks spanning a foot or so, and maybe in two places, and made that linkage draw via a cushioning spring or steal some hydraulic power from the pto pump on the "dyno" to press them in with a cylinder, the blocks would come and go and maintain a steady friction. One idea I saw used a large drive pulley from an old steam engine, but that might be difficult to find these days. They formed their blocks in partial arcs, laminated up from wetted, bent, kerf-relieved lumber, lam'd with urethane glue. Or cut biggun's from old barn beams. A flat pulley from a 45 combine might work as well. Or, use a standard rim, cut the brake pads to fit the inside contour of the rim (after a little time, they would conform to the cross section) and fit just fine. The key is to keep them cool.
***How are we thinking it would last with my 720D on the working end of the shaft?***
Well, let's see. A 720 would put out say, for sake of discussion, 60 hp at its 1125 rated speed. So, the 60*5252/1125 = 280 ft-# of torque. If you used a 38" rim, built to a 48" disk so you have a 2' radius where the brake rubbed, you have to be able to "absorb" the 280 ft-lbs BUT THEN FACTOR BACK UP FOR THE SLOW ROTATIONAL SPEED OF THE AXLE, which means you have to multiply the torque you are fighting as the axle speed goes down, i.e. gearing. I'd would have to count some turns of my VAC axle tomorrow to determine what a 540 pto speed translates to in terms of axle speed in fourth, third, second, or first gear since we can use the transmission of the donor tractor to amplify our load device, (or take the time to go through the road speeds chart to figure how fast the rear axle turns at a 540 pto speed on 28" rubber), but I'm too tired to do that right now and I need to let something for you to do), but....if you figure the axle ashing 28" tire which is 4' high and so is about 13' around (I'm rounding these things slightly to make it figure faster), then a 5 mph axle speed (kind of your nice plowing pace) would be turning the both rear axles at (5 mph*5280=26400/13' circumference= 2030 axle turns/hr/60 = 34 axle rpm, which I always thought would be pretty slow and manageable. But if you trap one axle still against the scale, then the other axle would turn twice as fast, or 68 rpm, still manageable. If hp in has to equal hp out, then the 60 hp at the engine at 1125 rpm generating 280 ft-lbs torque, and the axle is turning 68 rpm, then, 60*5252/68 rpm (axle speed) = torque of 4634 ft-lbs. So the question is, can you press the brake shoes in hard enough to exert a little over 2 tons of force on those block against the rim? I think you can. If you can exert 5 tons, and the rear end will handle the strain, you can load a 4020. If I made any mistakes, I'm sorry. It was a rough time flying all day.
Then again, you could always find a large truck rear end, and use those huge air brake pads to load it with, and it would probably be a long time until you wear those out. You could apply the load hydraulically against the air brake links, or just use a calibrated lever (meaning hanging weights on a lever handle to determine how much force you were applying), and you could still calculate the load for hp measurements. Being able to take measurements is a powerful tool when you are trying to tune an engine for maximum output.
wilamayb
11-18-2007 06:34:32
 Re: F.I.T. Just Pondering....!! in reply to F-I-T, 11-17-2007 18:14:14
I feel your pain with the flying during the hollidays. I'm not flying home until Wednesday. I'm flying through Dallas which is usually a mess, and then on to Nashville by 2:00 which is expecting bad weather on Wednesday. If I get home before 8:00 PM I will be greatly suprised. I got stuck here working the two days before the holliday b/c the other engineer spoke for the day off before I did. Somebody's gotta be there. Who knows what our guys would do without someone to point a finger at what they should be doing. LOL
The truck rearend sounds like the easiest if I could find an old rearend with the pancake style brake actuators without locks I could keep it very simple.
I could control load with a pressure regulator. I'm guessing I would need to cool those drums even with a 3.73 ratio the drums would be spinning at nearly 150 RPM, making over 1000 lb/ft of torque with my 720 on the working end of the driveshaft. They are gonna make some heat. I've got some old spray nozzles left over from the spray rig to help with that.
I'm thinking I would mount it on two large I-beams with some U-bolts, but I'm guessing I better stake it down to the gound as it might have a tendency to want to flip over sideways under heavy load if the amount of input torque exceeded the force needed to lift the axle. I guess I'll need the leaf springs still mounted to keep the axle from flipping over front/rear while braking. Maybe I can mount it with the springs flipped upside down?
I need to stop doing so much pondering and just get to work on it.
