J D Hydraulic Question
Ktheo1
11-17-2007 03:12:31
I have just got a JD hydraulic reset plow with the accumulator system.The only way to keep the bottoms from tripping is to tie the hydraulic lever down on my JD 2155.The plow is a JD F325. What I want to know is there any negative results to having the lever tied down constantly.?
Tx Jim
11-17-2007 04:08:20
 Re: J D Hydraulic Question in reply to patsdeere, 11-17-2007 03:12:31
If the accumulator is leaking causing the plow to trip then you acutally have the same as an internal leak which can cause the hyd oil to heat. Have you tried reversing the hyd. tips in the breakaway to see if your SCV is leaking internally? Tx Jim
wilamayb
11-17-2007 04:38:20
 Re: J D Hydraulic Question in reply to Tx Jim, 11-17-2007 04:08:20
Or just remove the couplers from the SCV alltogether for a minute to see what happens. I'm betting the old accumulator has thrown in the towel. I've never seen a plow with an accumulator. Is it rechageable? If so you may want to have it recharged by your dealer. It may prolong it for a couple more years. If the replacement is not too steep then you may just want to have your dealer replace/charge the accumulator.
