4455 question
thomasfrm33
11-16-2007 23:29:34
i recently purchased a real nice 1991 2950-houred 4455. i am the second owner of the tractor. i have put 90 hours on it. it runs good and strong,doesn't burn oil,and is very good on fuel. i am happy with it in every way,except that i needed it the other day in an emergency situation and i didn't have it plugged in and it took a few revolutions to start. it was 29 degrees the night before and around 38 when i went to start it. i got it started without using ether,but it still sorta bothers me. we had a 4255 before with 7500 hours and it would start right up at 15 degrees if i wanted it to. i realize no 2 tractors are alike,and it has always been plugged in it's whole life. batteries arent new,but their not wore out either. plus,it starts very fast in warm weather. should i just quit worrying? as i said,everything else is great about it. a real cream puff dream tractor. also,those are actual hours and it is a quad-range model. any thoughts/help would appreciated. thanks. josh
mjbrown
11-17-2007 04:59:21
 Re: 4455 question in reply to thomasfrm33, 11-16-2007 23:29:34
Do a little peace of mind service on the batteries or peace of mind replacemnt then quit worrying. My 4230 won't start without a little snort of ether in shirtsleeve weather but it does always start then runs great so I envy you. That engine was probably still at 29 degrees so that's not bad at all.
Tx Jim
11-17-2007 04:14:21
 Re: 4455 question in reply to JD G GUY, 11-16-2007 23:29:34
I have a 4255 with nearly 10,000 hrs that still cranks good in cold temps. I wouldn't worry about your 4455 if I were you I'd just be glad it cranks much better than a 4430!!!!! !!!!! 55 series you've just got to love them. Tx Jim
wilamayb
11-17-2007 04:15:15
Cranking speed will certainly affect how it starts. If that tractor has JD batteries they are "dry charge" which means they have to be serviced. You may want to pull the caps off to see if they are low on water. If you do have to add water you will want to buy a gallon of distilled water "free of minerals" to put in them. You should also take all the battery terminals off and clean off all the corrosion. If any of the factory crimped ends have been replaced with clamp on ends you should also remove the clamp on terminlas to clean the cable to terminals connection.
If a battery service and cable cleaning does not get you where you need to be then you may have to just buy some new batteries or have that starter motor looked at.
