3020 trans stuck?
pitchfork
11-16-2007 19:32:09
Help!!!!! My 1964 3020 would not go into reverse so I disconnected the shifter linkage to see if I could find reverse using the arm ( on the right side of the transmission ) itself. I pushed the arm down and now the top arm is stuck down and the lower arm is stuck also. What happened and what should I do?
Greasey Hand
11-18-2007 06:50:56
 Re: 3020 trans stuck? in reply to pitchfork, 11-16-2007 19:32:09
If your haveing shifting trouble more than likley
its the shaft in the trans, the sincros are gone. when the trans is fixed make sure you do the linkage on the outside the trans. If you dont you will be doin the inside gears over.
Had a guy bring a 3010 in to have the trans done
but he wouldn't spend the money to have the shift rods & levers on the outside done.
They had a loader on it so they used it for snow removel in the winter.
His son-in-law used it, Come summer he brought it back & we re done the trans again + the rods & levers outside the trans.
He had the money to do it wright then.
Its nothing to spend $1200 to $1500 On that One
shaft of gears etc. ++++++
msb
11-16-2007 19:56:56
Parked on an incline? One shifter is spring loaded so you can still shift it into gear. Let the clutch out easy and it will pop out of gear by itself. The trick is to know when to use 3rd and when to use the first reverse.
pitchfork
11-16-2007 20:07:48
 Re: 3020 trans stuck? in reply to msb, 11-16-2007 19:56:56
I'm confused because I never used a tractor with this kind of shifting setup. It is on flat ground.The upper arm was pushed down and is jammed against the lower arm. The lower arm springs up and down some though.
