72 4230 replace scv with pioneer iso
cob_crusher
11-16-2007 15:08:55
i am sick of replaced leaking scv with dealer for
$ 500 a side that don't last two years. has anyone changed them to pioneer standards. they dont leak and are effective. jd overengineered
crap.
powertech84
11-18-2007 08:54:55
 Re: 72 4230 replace scv with pioneer iso in reply to cob_crusher, 11-16-2007 15:08:55
i haven't had good luck with deere's iso kit. it seams they always leak, no matter how you do it, i've done probly 20 of those kits.oh, and throw those new style seals away, the orings seal way better, the only advantage to the seals is the couplers will slide easier
R. John Johnson
11-17-2007 06:30:00
I changed over my 4230 to the JD ISO sleeves. Works OK for me, but I don't do a lot of switching implements so that might have some bearing.
I read on another forum that there is another option. Go to a wrecker and exchange your coupler/valve assembly for one off of a 50 or 55 series. They were designed from the get go to be pioneer and work MUCH better. IF you find the right wrecker it doesn't cost much more than the kit from JD. I don't know if this will work or not, just what I read.
John
Bob
11-17-2007 10:39:12
 Re: 72 4230 replace scv with pioneer iso in reply to R. John Johnson, 11-17-2007 06:30:00
I don't think there's ANY difference between the conversion and the newer ones that were ISO OEM. IIRC, at least up to a point, they use the same parts.
rexhellwig
11-16-2007 18:59:40
If you're unhappy with the original 4230 couplers, just wait until whoever has been working on it installs Deere's ISO conversion.
Tech 7
11-16-2007 17:10:47
wow $500 per side? Pretty stiff charge for a barrel kit with the install. The ISO kit is actually cheaper than a kit which gives you the original JD couplers. When repairing there is a choice of using original O-rings/backup washers or new style V seals...I've had better luck with the O-rings As far as over-engineered.... not going to bother discussing. Bob
RobMD
11-16-2007 16:05:54
oh yeah, we get a lot of those, and blow outs are common, puking fluid, yada yada. We went universal ISO in 2006 on all our new gens.
Gerald J.
11-16-2007 15:19:41
Deere makes a kit to convert them to ISO.
I figured on converting my early 4020 to ISO using a double pioneer fitting, but I've not actually cut and flared the pipes where they need to be. On my 4020 the actual vavle(s) are up on the firewall with pipes to the couplers so that change is easier than it is on your tractor with the valves right at the valves.
I find that new tips stay in better than old tips but not all new tips work well.
Gerald J.
