520 crank specs
Eldon (WA)
11-16-2007 13:47:49
I cleaned up the crank with some crocus cloth and mic'd it. On the throw that spun the rod bearing it is .004" flat (2.875 to 2.871). Any options other than pulling the crank out and grinding?
Mike M
11-16-2007 14:26:53
 Re: 520 crank specs in reply to Eldon (WA), 11-16-2007 13:47:49
.004" flat ? That is called out of round by me ?
And yes you are going to have to have it ground depending on what bearings you can get or else you will hear it knock. I had a B with insert rods that was only .002" out of round and you could hear it.
Paul from MI
11-17-2007 08:14:10
 Re: 520 crank specs in reply to Mike M, 11-16-2007 14:26:53
Mike,
What's been your experience with the old shimmed bearings on out-of-roundness? I have been running an A with .002' out-of-round fro 30 years, no problems. I just set the clearnce on the tight side and used it.
Paul
Mike M
11-17-2007 15:40:26
 Re: 520 crank specs in reply to Paul from MI, 11-17-2007 08:14:10
The old type babbit shim adjustable rods are way more forgiving for sure.
