Unstyled B Head Gasket Question
Bguy
11-16-2007 13:07:49
I am going to pull the head off of my unstyled B and replace the head gasket. The head gasket from the JD dealer is open around the outside edges unlike the ones I used to get that had the metal rolled over the outside edge. Ever since I started using the new style gaskets I have had leaks sometimes and I don"t remember ever having this problem before. Does anyone know of a source for these old style gaskets?
Skyhawk Greg
11-18-2007 15:10:06
 Re: Unstyled B Head Gasket Question in reply to Bguy, 11-16-2007 13:07:49
Clooney told me a while back to use Permatex 3A. I used it on a B, and it worked just fine. Another good product is Copper Coat. It does wonders on head gaskets, even when used in diesel applications. I will never install another head gasket without Permatex 3A or Copper Coat. Both are available at a good auto parts store.
Greg
Will P
11-16-2007 18:55:52
Put Permatex 3 on the gasket. But not on the fire rings. Had the head on my B leaking too. Every Deere I put together now I use it. Clooney told me so.
Will
Hoss in Maine
11-16-2007 15:39:35
Can you say NAPA? Now how bout Felpro? Later Hoss
Mike M
11-16-2007 14:34:07
I have had the EXACT same problem as you and was kinda think I might of been the lone ranger. Last late B I did I smeared high tack or shellac or something on the insides or the edges I could easily lift up. Next one if I do anymore I'm going to get a gasket from Lubbock gaskets from TX they are more like what is on modern engines just a fire ring and no laminations to leak. I know some tractor pullers use these with good results. You just have to send them a sample. With all the JD's running around I would think they would start having them allready premade up but last I checked they didn't.
GeorgiaHayFarmer
11-16-2007 14:24:41
Hello,
I couldn't say about a source for the old style gaskets. When I install a head gasket, I usually spray some copper spray on it. Some folks use aluminum paint. Then torque and retorqe after running. My two cents..
Scott
