544 wheel loader goods and bads
Ranchingelec
11-16-2007 10:51:06
Just bought a 544 JD payloader. I am just wondering what the strong points are. What are the week points. Is it hard to add the third valve for a grapple. Thanks
Roy Suomi
11-16-2007 15:48:05
 Re: 544 wheel loader goods and bads in reply to Ranchingelec, 11-16-2007 10:51:06
544's are a decent machine..Sometimes the starter drags when trying to start the engine..Easily remedied , in the grill is the hydraulic pump..On the pump is a small Tee handle.Turn the Tee handle down till you feel a resistance then another turn will put the hydraulic pump out of stroke..This is especially usefull in the winter..After it starts , go back and turn the Tee handle back out till it stops turning..Steering and brakes operate off the rear pump , loader operates off the under floorboard pump..The splines on the loader pump have been known to strip out from rust..
RobMD
11-16-2007 11:21:48
I have to stand on the brakes to stop this 644A. same thing, only bigger. Engines are nice. Make sure the steering DOES NOT hang up when the tractor is IDLING. If the steering gets tough when the tractor is idling, then you will know the pump capacity is low - worn out.
