JD 50 Transmission
Jim from Stonep
01-30-2000 07:04:34
A neighbor has a JD50 that he can't get into 3rd gear. All the rest of the gears work fine. I am thinking of a bent fork. Is there anything else to consider here, before we start into it? Thanks, JIM
clooney
01-30-2000 07:19:02
 Re: JD 50 Transmission in reply to Jim from Stonepile, 01-30-2000 07:04:34
Jim, if 1st works OK, it is probably worn bearings on sliding gear shaft (that allows sliding gear shaft drive pinion to block it) or 1st-3rd-rev. shaft out of adjustment. Jim just pull the top cover & SEE IF YOU CAN PUT IT IN 3RD GEAR manually. Can you feel the gear move when you shift it, or can't you actually put it in that gear?
