Hey John.... he said: I unhooked the COIL WIRE from the points and attached a used 12v auto coil TO IT and it now sparks. I'm thinking if he hooked the external coil to THE COIL WIRE (not the points) the other end of the mag coil primary is gounded. If he takes one of the external coil's posts to the coil wire that USED to go to the points, and the other external coil post to ground, he then has two coil primaries in a loop. One with the pole piece inside the mag being excited by the rotating magnet acting as a source and the external coil's primary acting as a load. He also said or asked... My question is how to hook the leads on the coil for correct polarity? I'm a thinking the only way to check that is with a scope. Even the old lead pencil in the spark trick won't work here. You'd have to watch REAL close to see which side was orange when wouldn't you? LOL. One spark will be + to ground, the next - then + etc. He's basically made an alternator of the mag and is sending AC to the external coil who's cycles just happen to be timed to the engine's speed. The model L's mag is driven by one of the two cam shafts (the intake) and though it's rolling 1/2 crank speed I'm also thinking he'll get a spark near every TDC or each half turn of the cam/mag shaft. Wouldn't have bet a dime that a mag could cough up enough to make the external coil spark this way but I haven't seen it & he says it runs so it must! Also seems like a mag coil with a good secondary would make the rest of this mag work just fine & probably bettern what it's running on now donchya think? I may be all wet but this is the only way I can see of it having even a ghost of a chance of working. How 'bout you? Later.
