8100 exhaust gasket
old bones
11-15-2007 17:13:06
Help! Have a '96 8100 w/7.6L engine. The little "O" shaped gasket between the two manifold halves is leaking, blowing soot on the side of the block/head. Going to replace it, the manifold gaskets, and the bolts, but need advice. I have to take the heat shields off the manifold to access the bolts. As near as I can tell, I have to remove the plastic air intake tube from the air filter box and take that completely off the tractor first, as some of the shield bolts are behind and under the air tube. How do you do it?? Been wrestling with it for a couple hours and decided to ask before I end up wrecking anything. Maybe I"m taking the long scenic route going the wrong way. I sure could use some help. Thanks!
powertech84
11-19-2007 17:29:53
 Re: 8100 exhaust gasket in reply to old bones, 11-15-2007 17:13:06
the last guy got it right, just twist. as for the 8100 being gutless, thats not really true, the only bad thing about the 8100 comparted to 8200+ is if it has the original pistons, it probly starts harder than it should and your just killing time till they debond and try to escape
dieselade
11-16-2007 04:10:09
just curious about the 8100..i have heard it is a gutless machine on another farm webpage. Is it?I`m assuming maybe they try to make it do work not intended for it to do.
bunghammer
11-15-2007 18:58:51
Your going at it the right way. That tube has to be taken off so you can get to the bolts better. Its not a bad idea to get the manifold plained that way you know it is good and straight. Just my 2 cents worth.
old bones
11-15-2007 19:38:28
 Re: 8100 exhaust gasket in reply to bunghammer, 11-15-2007 18:58:51
How do you get the tube off the air box? Can't get the "notches" apart.
rexhellwig
11-16-2007 07:35:35
 Re: 8100 exhaust gasket in reply to old bones, 11-15-2007 19:38:28
Remove the hose clamp behind the fan and seperate the black rubber hose from the intake pipe. Take the front of the intake loose. Lift it up a few inches and swing it in an arc down and toward the cab door side of the tractor. You won't break anything. This will "twist" the tabs out of their notches and you can lift the pipe off.
