'36 B Block Question
Kris A NC
11-15-2007 06:47:04
Ok...I have a good one here for you. My brother thought I was crazy. I just took the head off of my "36B to get the pistons unstuck and to look at if I needed to just hone or bore them out. Well I know some about this process and I know that I was looking for a "step down" from wear when going from the top of the cylinder to where the piston runs. To my surprise it is actually a step up! So just to clarify instead of a smaller bore towards the head and larger towards the bottom, its opposite. Please tell me I am not crazy here.
Kris A NC
Mike M
11-15-2007 06:51:32
 Re: '36 B Block Question in reply to Kris A NC, 11-15-2007 06:47:04
Those unstyleds have a step made in the bore,larger up front above the piston travel,this is so you can start the pistons and rings in without needing a ring compressor.
Kris A NC
11-15-2007 07:24:34
 Re: '36 B Block Question in reply to Mike M, 11-15-2007 06:51:32
wow...thats pretty cool. I never heard that before. Thanks Mike. Another question, What is the tolerance for boring? Basically when should I hone and when should I bore. I don't know the specific numbers and I am curious. Thanks
Kris A NC
Mike M
11-15-2007 08:05:17
 Re: '36 B Block Question in reply to Kris A NC, 11-15-2007 07:24:34
I don't know if they had a spec. on those ? You can get away with alot in one and still have good results. Main thing is that they are not pitted all up. If it cleans up with a hone and would just have wear at the top of ring travel maybe back 1" to 1 1/2" and then stays fairly unworn I have gotten away with new rings and up to .010" wear with no problems. I once reringed an MT for a fellow that the block was not worth boring due to being broken. I think that one was almost up to .020" worn at the top and it really did help it enough to be useful again. You got to also go by what you want when done and how you plan to use it.
Kris A NC
11-15-2007 08:42:21
 Re: '36 B Block Question in reply to Mike M, 11-15-2007 08:05:17
basically I want to use it for light duty work. It more then likely won't be run real hard. From what I can tell I don't think it was used hard though. When you say .010" of wear, how do you measure that exactly?
Kris A NC
Mike M
11-15-2007 09:53:02
 Re: '36 B Block Question in reply to Kris A NC, 11-15-2007 08:42:21
You have to use an inside mic or a teloscope gauge with an outside mic. These 2 cyl engines normally wear in about the top 2 inches of ring travel and mostly on the top side of the cyl wall as mounted in the tractor.
Kris A NC
11-15-2007 10:47:32
 Re: '36 B Block Question in reply to Mike M, 11-15-2007 09:53:02
Thanks guys! I appreciate the help. I can't wait to hear her run for the first time! Have a great day
Kris A NC
teddy52food
11-15-2007 10:24:53
The cylinder on the flywheel side will be worn the most.
